Hi All,
Is it possible to modify the frame buffer layer in linux to use a frame reader hardware instead of a lcd_sgdma (used in the NEEK case) ? If the answer is yes, any pointers would be helpful. Regards DanyLink Copied
What is "a frame reader hardware" ?
Micheal,
a Frame Reader is an IP in the VIP library, it was introduced in quartus 9.0 http://www.alteraforum.com/forum/showthread.php?t=22319&highlight=frame+reader and http://www.alteraforum.com/forum/showthread.php?t=19710 might give you a better view.
