12748 Discussions
gcc generates bad code for volatile data
If you look at the generated code for reads of volatile char and short data, it seems that gcc assumes that the high bits of the register are undefined.
For instance:
int fubar(volatile char *bar) { return *bar; }
Generates:
ldbu r5, 0(r4)
andi r3, r5, 255
xori r2, r3, 128
addi r2, r2, -128
ret
Without the volatile the expected 'ldb r2, 0(r4)' is generated.
I've tried buiding gcc with PROMOTE_MODE defined (to its typical value) - but that has no effect.
Any other thoughts??
David
Some further info:
With 'volatile unsigned char *bar' both the 'ldbu' and 'andi rx,rx,0xff' instructions come from the 'zero_extendqisi2' pattern.
David
