- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
When trying to generate a system with SOPC builder, the following error occurs : # 2004.11.15 16:01:09 (*) running generator program for cpu_0
can't open perl script "files\texlive\xemtex\perl\lib": no such file or directory
error: generator program
for module 'cpu_0' did not run successfully. Even after reinstalling the tools, it is still not possible to generate the system. This is what I did : 1. Installing niosII kit, everything ok 2. Installing niosI software development flow to do some modifications on older projects. Software modifications could be done. 3. trying to regenerate a NiosII system not ok 4. remove all altera related software and reinstall --> still not ok anyone some ideas?
링크가 복사됨
3 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
OK problem solved.
It seems that I installed also a LaTex generator (TeTex), and this program gives an interaction with some shell variables in the SOPC builder system generation. By removing TeTex, it works again. But how can I generate pdf's now from my source code documentation? I feel a bit guilty by bothering you guys with this stupid kind of problems. But I was completely desperate at that moment, you know, when nothing seems to work anymore and everyone in the neighbourhood comes around with questions, ... BTW: Doxygen is a superb documentation generator. Stefaan.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Stefaan,
If you install a complete version of Cygwin, you can use one of the programs that comes with the psutils package.... ps2pdf. Of course, if you're already running on a _real_ OS (say Linux), then you likely have these utils, already. It has always worked, for exactly the same purpose, for me. - slacker- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
slacker,
How to install the complkete cygwin? Do it first, and than install the altera tools? Can it be done after installing the altera tools? Do I need to modify statrup scripts and so? I'm really a dummy if it comes to Linux, or Cygwin, ... I use it, that's all.
