12748 Discussions
generation problem SOPC builder
When trying to generate a system with SOPC builder, the following error occurs :
# 2004.11.15 16:01:09 (*) running generator program for cpu_0
can't open perl script "files\texlive\xemtex\perl\lib": no such file or directory
error: generator program
for module 'cpu_0' did not run successfully.
Even after reinstalling the tools, it is still not possible to generate the system.
This is what I did :
1. Installing niosII kit, everything ok
2. Installing niosI software development flow to do some modifications on older projects. Software modifications could be done.
3. trying to regenerate a NiosII system not ok
4. remove all altera related software and reinstall --> still not ok
anyone some ideas?
OK problem solved.
It seems that I installed also a LaTex generator (TeTex), and this program gives an interaction with some shell variables in the SOPC builder system generation.
By removing TeTex, it works again. But how can I generate pdf's now from my source code documentation?
I feel a bit guilty by bothering you guys with this stupid kind of problems. But I was completely desperate at that moment, you know, when nothing seems to work anymore and everyone in the neighbourhood comes around with questions, ...
BTW: Doxygen is a superb documentation generator.
Stefaan.
Stefaan,
If you install a complete version of Cygwin, you can use one of the programs that comes with the psutils package.... ps2pdf. Of course, if you're already running on a _real_ OS (say Linux), then you likely have these utils, already.
It has always worked, for exactly the same purpose, for me.
- slacker
slacker,
How to install the complkete cygwin?
Do it first, and than install the altera tools?
Can it be done after installing the altera tools?
Do I need to modify statrup scripts and so?
I'm really a dummy if it comes to Linux, or Cygwin, ... I use it, that's all.
