12748 Discussions
how I "set the BUILD_CC environment variable "?
hi all:
I am porting ncurses-5.5 to nios2 uclinux now.
Frist I edit configure.sub
add " | nios2 " in the "case $basic_machine in"
then I run:
./configure --build=nios2 --with-build-cc=nios2-linux-uclibc-gcc
but I check configure information and I find the message as bollow:
checking whether we are cross compiling... no
I checked the makefile ,I find the cc setting still use gcc, not nios2-linux-uclinbc-gcc
CC = gcc
CPP = gcc -E
CFLAGS = -O2
I read the install of ncures5.5. I got some information about crosscompile as bellow:
BUILDING NCURSES WITH A CROSS-COMPILER
Ncurses can be built with a cross-compiler. Some parts must be built
with the host's compiler since they are used for building programs
(e.g., ncurses/make_hash and ncurses/make_keys) that generate tables
that are compiled into the ncurses library. The essential thing to do
is set the BUILD_CC environment variable to your host's compiler, and
run the configure script configuring for the cross-compiler.
The configure options --with-build-cc, etc., are provided to make this
simpler. Since make_hash and make_keys use only ANSI C features, it
is normally not necessary to provide the other options such as
--with-build-libs, but they are provided for completeness.
Who can tell me how I "set the BUILD_CC environment variable to my host's compiler" ?
Thank a lot!
./configure --host=nios2-linux-uclibc- --with-build-cc=gcc --disable-shared ......
about config.sub, check ~/download/uClinux-dist.diff on how to add $basic_machine, eg wget
Index: user/wget/config.sub =================================================================== --- user/wget/config.sub    (revision 1) +++ user/wget/config.sub    (revision 3) @@ -274,6 +274,11 @@  m88110 | m6800 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)  ;; +    nios2 | nios2-* | nios2 | nios2-*) +  basic_machine=nios2-altera +  os=-linux +    ;; + # We use `pc' rather than `unknown' # because (1) that's what they normally are, and # (2) the word "unknown" tends to confuse beginning users.
hi hippo:
Thanks for you reply.
Frist I have successed make ncurese by you guide.
Then I must cross compile cdk(curses d k).It is a devlope tool for ncurses.
I still edit configure.sub and use configure option as your post.
but not select crosscompile option in configure process.
[alex@localhost cdk-5.0-20060220]$ ./configure --host=nios2-linux-uclibc --with-build-cc=gcc --disable-shared
loading cache ./config.cache
checking for X... (cached) libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking host system type... nios2-altera-linux-gnu
(cached) Configuring for linux-gnu
checking for package version... 5.0
checking for package patch date... 20060220
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
I try another ./configure option, for example:
[alex@localhost cdk-5.0-20060220]$ ./configure --build=nios2 --host--nios2-linux-uclibc --with-build-cc=gcc --disable-shared
[alex@localhost cdk-5.0-20060220]$ ./configure --host--nios2-linux-uclibc --with-build-cc=nios2-linux-uclibc-gcc --disable-shared
etc....
but I still fail.
Please help me.
If I make success, I will test the ncurses in my dvb. Then post porting method
to forum.The ncurses is a very helpful terminal tool for us.It can make tab,menu,
....in a terminal like a Kernel make menuconfig windows.
take a look at the config usage in ~/buildroot/package/ncurses/ncurses.mk
I didn't know cdk. sorry.
thank you hippo.
Can you tell me how I compile ~/buildroot/package/ncurses?
change "--with-shared" to "--disable-shared" in the configure command of the ~/buildroot/package/ncurses/ncurses.mk . You will need to removed the so (shared object) building.
The uClinux-dist (-test) has ncurses lib too. You'd better use this one, which is ported to uClinux. Check the library selection.
As a general rule, when you need lib or apps, check the uClinux-dist first.
Most lib or apps ports in buildroot are shared objects, which is not supported in current nios2.
You have to modify the mk files to remove shared.
hi:
I don't find ncurses lib in uClinux-dist-test.
I just find nessus app in /user. Can you tell where id the ncurses lib?
Thank you
You are right. It was missing in uClinux-dist.
So try buildroot's,
cd ~/buildroot make menuconfig
in Package Selection for the target-->[ *] ncurses , to select the package.
You have to edit mk file, in line 64,
change "--with-shared" to "--disable-shared" of the configure command of the ~/buildroot/package/ncurses/ncurses.mk
Then make. It will fail on shared object. But the static lib and header are ready, and you can try them.
hi hippo:
1. I make ncurses ~/buildroot/package/ncurses is oK.
2.as your guide :./configure --host=nios2-linux-uclibc- --with-build-cc=gcc --disable-shared ......
in sometimes maybe not correct.
sometimes must change "--host=nios2-linux-uclibc-" to "--host=nios2-linux-uclibc".
for example in ncurses ./confing, because "-" will be added by configure again.if you still use "--host=nios2-linux-uclibc-" ,it will make mistake.
Hi Alex,
You are right. Never add the last "-", just use "nios2-linux-uclibc" for --host= or --target= .
(I am lost, because I did not use configure for a while. I'm no more young...)
