hi all:
I am porting ncurses-5.5 to nios2 uclinux now. Frist I edit configure.sub add " | nios2 " in the "case $basic_machine in" then I run: ./configure --build=nios2 --with-build-cc=nios2-linux-uclibc-gcc but I check configure information and I find the message as bollow: checking whether we are cross compiling... no I checked the makefile ,I find the cc setting still use gcc, not nios2-linux-uclinbc-gcc CC = gcc CPP = gcc -E CFLAGS = -O2 I read the install of ncures5.5. I got some information about crosscompile as bellow: BUILDING NCURSES WITH A CROSS-COMPILER Ncurses can be built with a cross-compiler. Some parts must be built with the host's compiler since they are used for building programs (e.g., ncurses/make_hash and ncurses/make_keys) that generate tables that are compiled into the ncurses library. The essential thing to do is set the BUILD_CC environment variable to your host's compiler, and run the configure script configuring for the cross-compiler. The configure options --with-build-cc, etc., are provided to make this simpler. Since make_hash and make_keys use only ANSI C features, it is normally not necessary to provide the other options such as --with-build-libs, but they are provided for completeness. Who can tell me how I "set the BUILD_CC environment variable to my host's compiler" ? Thank a lot!Link Copied
./configure --host=nios2-linux-uclibc- --with-build-cc=gcc --disable-shared ......
about config.sub, check ~/download/uClinux-dist.diff on how to add $basic_machine, eg wgetIndex: user/wget/config.sub
--- user/wget/config.sub (revision 1)
+++ user/wget/config.sub (revision 3)
@@ -274,6 +274,11 @@
m88110 | m6800 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+ nios2 | nios2-* | nios2 | nios2-*)
+ basic_machine=nios2-altera
+ os=-linux
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
# (2) the word "unknown" tends to confuse beginning users.
hi hippo:
Thanks for you reply. Frist I have successed make ncurese by you guide. Then I must cross compile cdk(curses d k).It is a devlope tool for ncurses. I still edit configure.sub and use configure option as your post. but not select crosscompile option in configure process. [alex@localhost cdk-5.0-20060220]$ ./configure --host=nios2-linux-uclibc --with-build-cc=gcc --disable-shared loading cache ./config.cache checking for X... (cached) libraries /usr/X11R6/lib, headers /usr/X11R6/include checking host system type... nios2-altera-linux-gnu (cached) Configuring for linux-gnu checking for package version... 5.0 checking for package patch date... 20060220 checking for gcc... (cached) gcc checking whether the C compiler (gcc ) works... yes checking whether the C compiler (gcc ) is a cross-compiler... no checking whether we are using GNU C... (cached) yes I try another ./configure option, for example: [alex@localhost cdk-5.0-20060220]$ ./configure --build=nios2 --host--nios2-linux-uclibc --with-build-cc=gcc --disable-shared [alex@localhost cdk-5.0-20060220]$ ./configure --host--nios2-linux-uclibc --with-build-cc=nios2-linux-uclibc-gcc --disable-shared etc.... but I still fail. Please help me. If I make success, I will test the ncurses in my dvb. Then post porting method to forum.The ncurses is a very helpful terminal tool for us.It can make tab,menu, ....in a terminal like a Kernel make menuconfig windows.- Mark as New
take a look at the config usage in ~/buildroot/package/ncurses/ncurses.mk
I didn't know cdk. sorry.- Mark as New
thank you hippo.
Can you tell me how I compile ~/buildroot/package/ncurses?- Mark as New
change "--with-shared" to "--disable-shared" in the configure command of the ~/buildroot/package/ncurses/ncurses.mk . You will need to removed the so (shared object) building.
The uClinux-dist (-test) has ncurses lib too. You'd better use this one, which is ported to uClinux. Check the library selection. As a general rule, when you need lib or apps, check the uClinux-dist first. Most lib or apps ports in buildroot are shared objects, which is not supported in current nios2. You have to modify the mk files to remove shared.- Mark as New
hi:
I don't find ncurses lib in uClinux-dist-test. I just find nessus app in /user. Can you tell where id the ncurses lib? Thank you- Mark as New
You are right. It was missing in uClinux-dist.
So try buildroot's,cd ~/buildroot
make menuconfig
in Package Selection for the target-->[ *] ncurses , to select the package. You have to edit mk file, in line 64, change "--with-shared" to "--disable-shared" of the configure command of the ~/buildroot/package/ncurses/ncurses.mk Then make. It will fail on shared object. But the static lib and header are ready, and you can try them.
hi hippo:
1. I make ncurses ~/buildroot/package/ncurses is oK. 2.as your guide :./configure --host=nios2-linux-uclibc- --with-build-cc=gcc --disable-shared ...... in sometimes maybe not correct. sometimes must change "--host=nios2-linux-uclibc-" to "--host=nios2-linux-uclibc". for example in ncurses ./confing, because "-" will be added by configure again.if you still use "--host=nios2-linux-uclibc-" ,it will make mistake.- Mark as New
Hi Alex,
You are right. Never add the last "-", just use "nios2-linux-uclibc" for --host= or --target= . Thanks. (I am lost, because I did not use configure for a while. I'm no more young...)
