Comunicados
12748 Discussões
how can i tell the IDE to carry code to TCM
Colaborador honorário II
5.434 Visualizações
i write a program with assembly instruction,i want this program can be excuted in tightly coupled memory,but when i debug ,this code is not in the TCM,my TCM name is “onchipmemory",my program is follow:
start: nop
call test_code
br start
.section .onchipmemory
test_code:
addi sp,sp,-4
stw ra,0(sp)
movi r2,0x99
movi r3,0xaa
mul r2,r2,r3
ldw ra,o(sp)
addi sp,sp,4
ret
24 Respostas
2.124 Visualizações
:mad: No one can answer this question?
2.124 Visualizações
Did you try.section onchipmemory instead? Or have a look at the linker script, to find out what name it gave to your section.
2.124 Visualizações
thank you,i am glad to try it again
2.124 Visualizações
i tried in different way,but still can't seen the objectcode carried to the TCM,if anyone know how to do this with assembly instruction please tell me,thank you very much!
2.124 Visualizações
I have delayed this issue two weeks, please help me, thank you!:mad:
2.124 Visualizações
what does your linker script look like? In what section is your code put by the linker?
2.124 Visualizações
i can't see and edit the linker file,the file is created by the IDE automatically,can you tell me how to see and edit the linker file? thank you!
2.124 Visualizações
If you are using the IDE, it is in your system library > Debug > system_description > generated.x
2.124 Visualizações
TO_BE_DONE
2.124 Visualizações
From what I can read in the linker script, you don't have any section called onchip_memory. You have instruction_onchipmemory (address 0x08000000) and onchip_memory2_0 (address 0x04000000).
One of those should be your TCM memory. Use its name as section name, without the . in front, and see if it works.
2.124 Visualizações
the instruction_onchipmemory (address 0x08000000) is sure my TCM, the IDE also crectly compilated my instructions and asign the code address at the TCM zone, but when i debug the IDE din't exicute the download action to the TCM,it only download the program to de extern sram. if i use the instruction_onchipmemory as the section name without dot front of it ,the IDE would asign a increct address to the TCM section.
2.124 Visualizações
the IDE can crectly compilated and download the program to the SRAM and TCM if the program is writen by C, or the section of TCM code is writen by c but called by the assembly main function, but when i develope my program with pure assembly instruction the IDE can't exicute the download action to the TCM,i don't know why and how to solve the problem.
2.124 Visualizações
That's odd... As long as the object file generated from your assembly source code is included in the project and linked with the rest there shouldn't be any difference between an assembly function and a C function...
I expect that you used a dual port memory with one port connected to the TCM interface and the other on the data master? Do they have both the same address? Did you try to switch the two ports? IIRC I had some trouble when the TCM interface was connected to the s2 port on the on-chip memory. Connecting it to s1 worked better. Something to do with how the BSP tools parse the ptf file, I guess.
2.124 Visualizações
I recreated a hardware project to test the TCM,i wrote the program with pure assembly instruction and encount a new problem:when the IDE complete dowloading the code to SRAM and TCM ,I found that the instruction code is not be download to the TCM successfully,the data in the TCM zone is not be changed at all! is it the problem of IDE? is it the problem of my hardware project? is it the problem of my simple assembly instruction program? if anyone know what the problem is ,please tell me,thanks!
in my hardware project my TCM's name is instruction_onchipmemory,the folowing is my testing assembly instruction program:
.global main
.type main, @function
main: addi sp, sp,-12
stw ra, 8(sp)
stw fp, 4(sp)
mov fp, sp
loop: call tcm_test
br loop
//the folowing instruction will be executed in tightly coupled memory
// the tightly coupled memory's name is instruction_onchipmemory
.section .instruction_onchipmemory
tcm_test: addi sp, sp,-4
stw ra, 0(sp)
movi r2,0x123
movi r3,0x345
mul r2,r2,r3
mov r4,r2
ldw ra,0(sp)
addi sp,sp,4
ret
2.124 Visualizações
Could you show us your SOPC system with all the connections?
2.124 Visualizações
How to connections sent to you? I sent you the picture on the connect, or files? By e-mail sent to you or in the forum reply?
thanks
2.124 Visualizações
You can take a screenshot of SOPC Builder and attach it to your reply on the forum
2.124 Visualizações
http://b26.photo.store.qq.com/http_imgload.cgi?/rurl4_b=1fd7dc8eb6dd34c3d4238916da522f6bc30e4987fd979528f0f7ffcf67199886be7db29724814d6ce0d317840f65a5a333c354cef75385f4881485ffa03c8f7ae324742b17668c7f99b47ac63567f0d281c0da3d&a=26&b=26
it's my partion of connections in sopc builder . Now, the problem is that the c code can work well with tcm, but the program with assembly instruction can not work.
2.124 Visualizações
:p pdf file sent to you . thanks
2.045 Visualizações
The SOPC system looks good, and as far as I can tell the call assembly instruction uses a 28-bit address, so it should be able to jump to the TCM. I can find any reason for your problem...
It could be something with the way the compiler/linker processes assembly files.
What if you try to put a C function in the TCM, but use an asm() block inside?
Responder
