12748 Discussions
how to add application to uclinux?
i want to add hello_world to uclinux,
the code is:
# include <stdio.h>
main()
{char *str="Hello world !";
printf("%s\n",str);
exit(0);
i have 3 problems:
1.how to write makefile,can you give me the whole code??
2.when i creat maketarget,there has a blanket(build target), what content should i fill in?
3.after build the application,how to upload the application to the linux?
thanks!!!
Just a partial reply, but you&#39;ll want your Makefile to look something like (I&#39;m assuming that you&#39;re using the eclipse IDE, and that you set up a project for this):
include Settings.mak
include Rules.mak
OBJS = yourfile1.o yourfile2.o etc.o
all: yourprogram.exe
yourprogram.bin: $(OBJS)
(not including the dashes, obviously)
then build the project and copy the yourprogram.exe file into /bin in the filesystem project, then build it and upload it.
Not a complete response, but I hope that this helps.
Chris Lansdown
Solar Technology Inc.
it&#39;s great!! thank you!! clansdown http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
Is there a quicker way uploading an application to the board? Putting the exe file into the fs project and uploading takes a while. Thanks in advance for ur help.
