12748 Discussions
how to build ijg libjpeg in macrotronix nios linux
how to build ijg libjpeg in macrotronix nios linux?
i want to use libjpeg in nios linux project,thank you!
You can check "Build libjpeg" in user setting of uClinux-dist.
--- Quote Start ---
originally posted by hippo@Jan 9 2007, 10:47 AM
you can check "build libjpeg" in user setting of uclinux-dist.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20439)
--- quote end ---
--- Quote End ---
thank you!
where are user setting of uClinux-dist?
make menuconfig
Main Menu --> Library Configuration
[*] Build libjpeg
it will build the source in dir uClinux-dist/lib/libjpeg .
