公告
12748 讨论
how to calculate the number of M9k that nios onchip memory occupied?
名誉分销商 II
2,332 次查看
hi everyone
in project A, i set the nios onchip memory size to be 20480 bytes, the quartus told me(Fitter report) it occupy 20 M9Ks, its implementation bits is 163840
then i use copy project in quartus, copy the project A to a new place, let's name it project B, i re-compilate the project, the Fitter report told me the nios on chip memory occupy 32M9Ks!
i am a little confused,
in binary system, the 20480 bytes should occupy the same space with 2048*16 bytes, that is 2048*16*8=83,886,080bits=28.4 M9Ks, that is 29M9Ks
why in project A it only occupy 20 M9Ks?
why in project B it occupy 32 M9Ks?
thanks!
0 项奖励
4 回复数
名誉分销商 II
1,378 次查看
--- Quote Start ---
--- Quote End ---
This is fine and makes perfect sense. 1024 bytes per M9K block. 20 x 1024 bytes = 20 M9K blocks.
--- Quote Start ---
--- Quote End ---
It shouldn't. I can only presume you are not (quite) doing what you think you are in copying the project.
--- Quote Start ---
--- Quote End ---
I dare say you are 'a little confused'. 20480 bytes fits into 20 x M9K blocks, as project A confirms. 28.4, 29 or 32 are not necessary.
I suggest you do a little more digging.
Cheers,
Alex
0 项奖励
名誉分销商 II
1,378 次查看
Probably you can attach the fitter report.
0 项奖励
名誉分销商 II
1,378 次查看
hi, thanks for replying.
i check the fitter report:
http://www.alteraforum.com/forum/attachment.php?attachmentid=11266&stc=1
i also think that may be my problem, but the fitter report shows that the 163840 bit occupy 32M9ks
by the way, when i change the on chip memory size from 20480 bytes to 16384 bytes, the fitter report told me it takes only 16 M9ks
can you give me more advise? thanks!
0 项奖励
名誉分销商 II
1,378 次查看
Something that caught my eye: "Note: Fitter may spread logical memories into multiple blocks to improve timing. The actual required RAM blocks can be found in the Fitter Resource Usage section."
You can try changing SEED, system frequency.
What version are you using before 15.0?
0 项奖励
回复
