12748 Discussions
how to conect external hardware to the nios ii
hello everyone!!
well i need some help, im trying to conect some test hardware to my nios, but i m not sure how to do it. I have the program in c and i have to put some externals interruptions and depend on the interruptions, load some data from some externals register and i try to know how to do this. I did some kind of simulations using pushes and it works but i really need to put this hardware because i m going to conect this hardware.
i hope someone can help me
thak you
HI
use Spi
regards
M Kalyansrinivas
Get aquainted with this webpage and bookmark it:
http://www.altera.com/literature/lit-nio2.jsp
Basically there are a few ways to interact with with external hardware:
1 - Use PIO ports. These are just regular I/O ports that connect to your NIOS processor and go to the outside world. You can write to them, read from them ,get interrupts from them, etc.
2 - Export part of the avalon bus from the SoPC system so your logic can be accessed from the processor.
3 - Create your own custom component to interface between the NIOS and your hardware.
Jake
thanks a lot, i will try to do and if i have more doubs i ask thank you very much
bgea
Hi
ok Thankyou good information
regards
kalyan
hi,
i need a help
how to connect CAN opencore to nios Avalon bus?
i want to integrated CAN opencore as a new component on SOPC builder Altera Cyclone II.
Hi
How to interface the Avalon st interface to Nios processor
