Hi all
I am trying to learn the usage of avalon interface I created a ROM in verilog and i want to read the data into Nios Rom is connected as a avalon slave to Nios II processor But i see the data read into NIOS from the particular address is not as i modeled the ROM What is the mistake i am doing Please help regards M KalyansrinivasLink Copied
Here with i paste the result i am getting
Memory 32 should have an output of 42 but it shows 0 which is incorrect nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Hello from Nios II! data_rom_out 0 = 0 data_rom_out 1 = 12 data_rom_out 2 = 14 data_rom_out 3 = 16 data_rom_out 4 = 18 data_rom_out 5 = 20 data_rom_out 6 = 22 data_rom_out 7 = 24 data_rom_out 8 = 26 data_rom_out 9 = 28 data_rom_out 10 = 30 data_rom_out 11 = 32 data_rom_out 12 = 34 data_rom_out 13 = 36 data_rom_out 14 = 38 data_rom_out 15 = 40 data_rom_out 16 = 42 data_rom_out 17 = 44 data_rom_out 18 = 46 data_rom_out 19 = 48 data_rom_out 20 = 50 data_rom_out 21 = 52 data_rom_out 22 = 54 data_rom_out 23 = 56 data_rom_out 24 = 58 data_rom_out 25 = 60 data_rom_out 26 = 62 data_rom_out 27 = 64 data_rom_out 28 = 66 data_rom_out 29 = 68 data_rom_out 30 = 70 data_rom_out 31 = 72 data_rom_out 32 = 0 data_rom_out 33 = 12 data_rom_out 34 = 14
