12748 Discussions
how to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash?
thanks !
with my regard!
quartusII can generate .hexout when u compile ur nios processor or when u compile ur digital design....
use the .hexout file to download to the appropriate portion of the flash memory then u hav ur FPGA config in ur flash then.....
cod
i have found my workspace directory! not find .hexout file,it show the followed message : it need hardware--image!coluld you be kind to specify it with a detailed way!
