12747 Discussions
how to run uclinux on ep2s60f broad
hello evryone.
I created a uclinux1.4 project on development broad about ep2s60fes and built successfully,but I don't know to run it, I want udapte operation to USB-blaster0,it'is wrong with it
content:
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
Aug 29, 2005 11:42:10 AM - (??) nios2-flash-programmer: Launching Quartus Progra
mmer to download:
c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es/syste
m/altera_nios_dev_board_stratix_2s60_es.sof
Unable to synchronize with target.
Aug 29, 2005 11:43:14 AM - (??) nios2-flash-programmer: Error opening target har
dware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
How should I do?
the more, Whether the demand bootloader.
Sounds like you're having difficulty with the flash programmer itself. Have you been able to build and upload simple standalone applications using the Altera Nios II IDE?
Hi ken, thanks your advice;
-I built a application (hello) successful .but can't update,Because there have no OS ,
-It created vmlinux.bin when I built linux kernel ; Whether demand a bootloader?
-How can i build linux kenerl and load to development kit broad ,
-Do you have the data of this aspect?
thanks again!
How i can create a .sof file(ex. linux.sof) ,I can use what's tools?
Check your PM, I replied to your copy of the message there.
