12745 討論
how to use "msgget" in nios2 uclinx?
榮譽貢獻者 II
2,682 檢視
hi:
I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed.
After exec, but the return value is -1
I want to use cmd "IPCS" to check the ipc ID. but shell return: not found.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
How can I do? The same function "msgget" used in other uClinx os is OK.
Why failed in nios2 uClinux? Why the cmd "IPCS" not support nios2 linux?
Thanks a lot.
0 積分
13 回應
榮譽貢獻者 II
1,882 檢視
Today I write a test.c for test ipc/msg. frist I make it use GCC, it work fine in FC4.
Then I make it use nios2-linux-uclibc-gcc, and exec it. But msgQ not inplemented
following is the return information in shell.
# msgsend
msgget: Calling msgget(0x4d2,01666)
msgget: Function not implemented#
So I check the nios2 kernel configure, I slect "general-->POSIX Message Queues" setting and rebuild the kernel.
follow is rebuilding kernel information:
[Alex@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- zImage
no emulation specific options.
CHK include/linux/version.h
SPLIT include/linux/autoconf.h -> include/config/*
CHK include/nios2_system.h
perl -I/home/Alex/linux-2.6.x/arch/nios2nommu/scripts /home/Alex/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < ../nios2_ptf/CRM3500N_cpu_v2.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
make[1]: “arch/nios2nommu/kernel/asm-offsets.s”&#26159;&#26368;&#26032;&#30340;&#12290;
CHK include/asm-nios2nommu/asm-offsets.h
CHK include/linux/compile.h
CHK usr/initramfs_list
CC ipc/mqueue.o
CC ipc/msgutil.o
LD ipc/built-in.o
GEN .version
UPD include/linux/compile.h
CC init/version.o
LD init/built-in.o
LD vmlinux
SYSMAP System.map
OBJCOPY arch/nios2nommu/boot/compressed/vmlinux.bin
GZIP arch/nios2nommu/boot/compressed/vmlinux.bin.gz
LD arch/nios2nommu/boot/compressed/piggy.o
LD arch/nios2nommu/boot/compressed/vmlinux
OBJCOPY arch/nios2nommu/boot/zImage
Kernel: arch/nios2nommu/boot/zImage is ready
I find CC ipc/mqueue.o , so I think maybe ipcs will suppourt.
CC ipc/msgutil.o
LD ipc/built-in.o
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I exec the zImage, but ipcs cmd still lost.
And exec the test bin still failed.
The following is the test.c for test ipc/mqueue
# include <sys/types.h># include <sys/ipc.h># include <sys/msg.h># include <stdio.h># include <string.h># define MSGSZ 128
* Declare the message structure.
typedef struct {
long mtype;
char mtext[MSGSZ];
} message_buf;
main(){
int msqid;
int msgflg = IPC_CREAT | 0666;
key_t key;
message_buf sbuf;
size_t buf_length;
* Get the message queue id for the
* "name" 1234, which was created by
* the server.
key = 1234;
(void) fprintf(stderr,
"\nmsgget: Calling msgget(%#lx,\%#o)\n",
key, msgflg);
if ((msqid = msgget(key, msgflg )) < 0) {
perror("msgget");
exit(1);
else
"msgget: msgget succeeded: msqid = %d\n",
msqid);
* We&#39;ll send message type 1
sbuf.mtype = 1;
msqid);
(void) strcpy(sbuf.mtext, "Did you get this?");
msqid);
buf_length = strlen(sbuf.mtext) ;
* Send a message.
if (msgsnd(msqid, &sbuf, buf_length, IPC_NOWAIT) < 0) {
printf ("%d, %d, %s, %d\n", msqid, sbuf.mtype, sbuf.mtext, buf_length);
perror("msgsnd");
exit(1);
else
printf("Message: \"%s\" Sent\n", sbuf.mtext);
exit(0);
Pleaes let us solver the question togeter. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
榮譽貢獻者 II
1,882 檢視
for ipcs you can enable it in busybox under buildroot.
But I don&#39;t know if nios2 kernel support it correctly.
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
but i don&#39;t know if  nios2 kernel support it correctly.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15279)
--- quote end ---
--- Quote End ---
I enabled msg queue in kernel, run ipcs,
# ipcs
kernel not configured for shared memory
kernel not configured for semaphores
kernel not configured for message queues#
榮譽貢獻者 II
1,882 檢視
Thank you hippo.
I use make menuconfig and make in ~/buildroot/build_nios2/busybox dir.
frist I enable " ipcs"
second "make"
but how can I update roofs? I use"make" in `/buildroot dir,but the busybox exec file is not the nios2 exec file
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
originally posted by hippo+may 11 2006, 01:47 am--><div class='quotetop'>quote (hippo @ may 11 2006, 01:47 am)</div>
--- quote start ---
<!--quotebegin-hippo@May 11 2006, 02:10 PM
--- quote end ---
--- Quote End ---
# ipcs
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15281)</div>
[/b]
--- Quote End ---
HI hippo:
What meanings the "kernel not configured for message queues"?
Is it meaning the nios2 uclinux kernel not support message queues?or I lost some
setting in kernel configur?
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
originally posted by alex824@May 11 2006, 05:11 PM
thank you hippo.
i use make menuconfig and make in ~/buildroot/build_nios2/busybox dir.
frist i enable " ipcs"
second "make"
but how can i update roofs? i use"make" in `/buildroot dir,but the busybox exec file is not  the nios2 exec file
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15286)
--- quote end ---
--- Quote End ---
Please follow step12 in the buildroot guide.
榮譽貢獻者 II
1,882 檢視
TO_BE_DONE
榮譽貢獻者 II
1,882 檢視
please check ~/apps/mqueue .
榮譽貢獻者 II
1,882 檢視
--- Quote End ---
SysV IPC can not support without MMU.
I am not sure if msg queue is supported in Nios II.
please debug the kernel ipc/ to find out.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15303)</div>
--- Quote End ---
I have a doubt
I use "msgget", "msgsnd" "msgrcv" in winbond arm7 cpu is ok.
The winbond arm7 cpu without MMU.
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
--- Quote End ---
--- Quote End ---
I have a doubt
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15314)</div>
--- Quote End ---
There may be bugs for msg queue on Nios2 kernel.
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15310)
--- quote end ---
--- Quote End ---
I make ~/apps/mqueue but failed. So I rework the Makefile of mqueue .
But I meet a question. If I want to use mqueue ,frist I must make ~/apps/mqueue/src to make libmqueue.a
So I added "ar = nios2-linux-uclibc-ar&#39; id makefile.
but in make process, the cc use gcc not nios2-linux-uclibc-gcc,so the libmqueue.a
is wrong.
榮譽貢獻者 II
1,882 檢視
--- Quote Start ---
originally posted by alex824+may 12 2006, 02:51 pm--><div class='quotetop'>quote (alex824 @ may 12 2006, 02:51 pm)</div>
--- quote start ---
<!--quotebegin-hippo@May 11 2006, 09:11 PM
--- quote end ---
--- Quote End ---
is wrong.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15316)</div>
[/b]
--- Quote End ---
Please look at download/mx140apps.diff, and modify the Makefile.
榮譽貢獻者 II
1,882 檢視
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15319)</div>
--- Quote End ---
Thanks hippo.
I have already rework ~/app/mqueue fo following mx140apps.diff.
But the mx140apps.diff not dabble at the link *.A .
Can you give us a template?
回覆
