linux on DE2
I try to run linux on DE2,when download vmlinux.bin into ram,it happen :
Linux version 2.6.11-uc0 (ty@ty024) (gcc version 3.4.1 (Altera Nios II 5.1 b73))
# 2 Thu Apr 27 20:24:19 2006
on
.4.1 (AlteNios II
I 5.1 b73))# 2 Thpport © 2004 Microtronix Datacom Ltd.
s ilt 1 zonelists
I support ©d line: root=/dev/mtdblock0 ro
BuD hash table entries: 64 (order: 6, 1024 bytes)
tdblock0 ro
PIsh table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hatable entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
288k data)
ble: 6372k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data)
Registered protocol family 16
512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
000ial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004cheduler anticipatory registered scheduler noop registered
io sededuler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
ksize
driver initialized: 16 RAM disks of 4096K size 1024 blocksize
tera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bankps: 1
Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-susing not available
code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Usin"Altera NDK flash (AMD)":
nition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
s2" extends beyond the end of device "Altera NDK flash (AMD)" -- size truncated
to 0x200000
device "Altera NDK flash (AMD)" --nel"
truncated to 0x200000
0x00000000-0x00200000 : "loader/kernel"
er configuration" is out of reach -- disabled
td: partition "User configuration" is out of reach -- disabled
fe configuration" is out of reach -- disabled
td: partition "safe configuration" is out of reach -- disabled
NET: Registered protocol family 2
ished hash table entries: 512 (order: 0, 4096 bytes)
TCP establash table entries: 512 (order: -1, 2048 bytes)
tes)
TCP bind h configured (established 512 bind 512)
bytes)
TCP: Hash tables family 1
NET: Registered protocol family 17
ios II 5.1 b73))# 2 Thu Apr 27 20:24:19 2006
on
.4.1 (AlteNios II
suilt 1 zonelists
I support © line: root=/dev/mtdblock0 ro
BID hash table entries: 128 (order: 7, 2048 bytes)
dblock0 ro
Phash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache sh table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
288k data)
ble: 6360k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data)
el panic - not syncing: Can't create rootfs
, 4096 bytes)
Kernel panic - not syncing: Can't create rootfs
It may need filesystems,i want to know how and where i should download the filesystems into ram?
thank you!!
The file system should be loaded at address 0x200000.
You can adjust partitions in the file altera.c
