12745 Discussions
i2c slave based on interrupt
FRava3
Hello, is there an example of Avalon i2c slave which can generate an interrupt on the NiosII when an i2c query arrives ?
All examples I found was Master or slave based on polling.
Fpga: Arria10
mcu : NiosII
Quartus 17
Thank you
GuaBin_N_Intel
I didn't find out any ISR handling for I2C. You can refer to one of UART example to declare and initialize the ISR https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii52006.pdf, example 8-1, pg8-16
