initramfs Error !
Hi All .
I am new uclinux .
I did step by step in nioswiki page but I can't success with toolchain .
I got error when "make romfs " --> initramfs error . after make romfs I had romfs dir but the most of subdir in romfs is empty except romfs/etc ---> what wrong ???
I think the reason is uClinux-dist lack file . Ex : I don't have file "linux-2.6.x/usr/.initramfs_data.cpio.gz.d" .
I download uClinux-dist-20060803.tar.bz2 + uClinux-dist-20060803-nios2-02.diff.gz + nios2gcc.tar.bz2 at nioswiki page
this is message when "make romfs"
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow
for i in uClibc /home/vietluong/Nios/uClinux-dist/prop ; do
[ ! -d $i ] || make -C $i romfs || exit $? ;
done
/bin/sh: nios2-elf-gcc: command not found
make[2]: Entering directory `/home/vietluong/Nios/uClinux-dist/uClibc'
[ -e /home/vietluong/Nios/uClinux-dist/romfs/lib ] || mkdir /home/vietluong/Nios/uClinux-dist/romfs/lib
if [ "" ]; then
romfs-inst.sh /lib/lib.so;
fi
make[2]: Leaving directory `/home/vietluong/Nios/uClinux-dist/uClibc'
make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/lib'
make[1]: Entering directory `/home/vietluong/Nios/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/include'
make[1]: Entering directory `/home/vietluong/Nios/uClinux-dist/user'
for i in boa busybox cgi_generic dhcpcd-new fdisk ftp ftpd-new games inetd init mount sash telnetd /home/vietluong/Nios/uClinux-dist/prop ; do
done
make[2]: Entering directory `/home/vietluong/Nios/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entering directory `/home/vietluong/Nios/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: cannot stat `boa': No such file or directory
make[3]: *** [romfs] Error 1
make[3]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user/boa/src'
make[2]: *** [romfs] Error 2
make[2]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user/boa'
make[1]: *** [romfs] Error 2
make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user'
make: *** [romfs.subdirs] Error 1
Please help me !!!
thanks .
You only need to create the directory boa to bypass this error.
mkdir ~/Nios/uClinux-dist/romfs/bin/boa
--- Quote Start ---
originally posted by marhm@Nov 22 2006, 04:22 PM
you only need to create the directory boa to bypass this error.
mkdir ~/nios/uclinux-dist/romfs/bin/boa
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19581)
--- quote end ---
--- Quote End ---
Hi All !
My problem is solve .
I just want tell little : I got some foolish error and the reason is my machine
Thanks All for help me !
thanks again .
