12748 Discussions
install "Nios II Linux v1.4 released"
hi!
i've just tried to install the downloaded linux. there was an error message:
"Cygwin extension were not installed properly.
Please see README for instruction on how to install them manually"
what does that mean? could not find a hint in README on how to install
them manually.
system : XP, quartus v51, nios v51.
torsten
hi,
try to follow the thread on a debian distribution.
does not run succesfully till the end.
regards torsten
--- Quote Start ---
originally posted by torsten grevsmuehl@Apr 21 2006, 04:43 PM
hi,
regards torsten
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14543)
--- quote end ---
--- Quote End ---
I use Fedora Core 5 and Slackware 10.2 .
Jdhar uses Ubuntu.
Where do you fail?
Please check if you have gcc3.xx ?
Torsten,
I have built uClinux successfully on the Debian platform. There were small problems (which maybe Debian-related?), but basically it works OK for me.
What fails exactly? Please post some details on this thread.
TO_BE_DONE
The cross gcc is finished.
the problem is in making elf2flt .
try remove toolchain_build_nios2/elf2flt dir, and make again.
if still failed in making elf2flt, check those include headers.
hi!
sorry, it&#39;s me again.
what include files should be checked at which location.
what Makefile should i try again?
could i have a problem with permissions etc.?
regards grevsmuehl
--- Quote Start ---
originally posted by torsten grevsmuehl@Apr 24 2006, 08:49 PM
hi!
what makefile should i try again?
regards  grevsmuehl
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14602)
--- quote end ---
--- Quote End ---
Please check this first.
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:38:22: ansidecl.h: No such file or directory
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:39:20: symcat.h: No such file or directory
On my FC5, there are /usr/include/ ansidecl.h and symcat.h .
hootsmon, would you give some hints about Debian?
Buildroot runs in user account. It does not need root account. So the user permissions should be Okay.
--- Quote Start ---
originally posted by torsten grevsmuehl@Apr 24 2006, 06:58 PM
make -j1 -c /home/grev/buildroot/toolchain_build_nios2/elf2flt all
make[1]: entering directory `/home/grev/buildroot/toolchain_build_nios2/elf2flt&#39;
gcc -g -o2 -dpackage_name=\"\" -dpackage_tarname=\"\" -dpackage_version=\"\" -dpackage_string=\"\" -dpackage_bugreport=\"\" -dstdc_headers=1 -dhave_sys_types_h=1 -dhave_sys_stat_h=1 -dhave_stdlib_h=1 -dhave_string_h=1 -dhave_memory_h=1 -dhave_strings_h=1 -dhave_inttypes_h=1 -dhave_stdint_h=1 -dhave_unistd_h=1 -dhave_fcntl_h=1 -dhave_unistd_h=1 -dhave_vprintf=1 -dhave_dcgettext=1  -dtarget_nios2 -i/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/ -o elf2flt /home/grev/buildroot/toolchain_build_nios2/elf2flt/elf2flt.c /home/grev/buildroot/toolchain_build_nios2/elf2flt/stubs.c /home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/libbfd.a /home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/libiberty/libiberty.a
in file included from /home/grev/buildroot/toolchain_build_nios2/elf2flt/elf2flt.c:52:
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:38:22: ansidecl.h: no such file or directory
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:39:20: symcat.h: no such file or directory
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:834: error: parse error before "params"
/home/grev/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd/bfd.h:838: error: parse error before "params"
--- Quote End ---
I see this exact behaviour on my Debian platform too, so now we can confirm this is definitely Debian related (I thought it might be).
The good news is there&#39;s a 1-line workaround, but for now I have to work from memory, since I&#39;m not at my Debian PC today. Basically, just hack elf2flt&#39;s Makefile, so that "ansidecl.h" is found in the include path. I don&#39;t know why only Debian need this. I will make a patch tomorrow, but in the meantime, give this a try....
1) cd ~/buildroot/toolchain_build_nios2/elf2flt/
2) find .. -name "ansidecl.h" -print
* Note path for "ansidecl.h", I think its in current dir?
3) vi Makefile
* search for "-I"
* add another -I {path} so that ansidecl.h and friends are includable
4) make clean
5) make
6) make install
7) cd ~buildroot
8) make
That should make buildroot OK. At this stage I recommend rebuilding busybox, as per step# 12 of hippo&#39;s buildroot guide.
Good luck http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Here is my patch to make elf2flt compile properly on Debian platform....
Index: toolchain/elf2flt/elf2flt.mk =================================================================== --- toolchain/elf2flt/elf2flt.mk        (original) +++ toolchain/elf2flt/elf2flt.mk        (working copy) @@ -20,6 +20,7 @@        (cd $(ELF2FLT_DIR); rm -rf config.cache;                $(ELF2FLT_DIR)/configure                --with-bfd-include-dir=$(BINUTILS_DIR1)/bfd/ +               --with-binutils-include-dir=$(BINUTILS_DIR)/include/                --target=$(REAL_GNU_TARGET_NAME)                --with-libbfd=$(BINUTILS_DIR1)/bfd/libbfd.a                --with-libiberty=$(BINUTILS_DIR1)/libiberty/libiberty.a \
Thorsten, here&#39;s how to apply it....
1) Save the patch into ~/download/elf2flt.diff
2) cd ~/buildroot
3) patch -p0 <~/download/elf2flt.diff
4) rm -rf toolchain_build_nios2/elf2flt
5) make
Hippo, does this patch look allright to you?
Will it have any affect on non-Debian users?
Should something like this go in svn?
--- Quote Start ---
originally posted by hootsmon@Apr 26 2006, 11:49 AM
here is my patch to make elf2flt compile properly on debian platform....
index: toolchain/elf2flt/elf2flt.mk =================================================================== --- toolchain/elf2flt/elf2flt.mk        (original) +++ toolchain/elf2flt/elf2flt.mk        (working copy) @@ -20,6 +20,7 @@        (cd $(elf2flt_dir); rm -rf config.cache;                $(elf2flt_dir)/configure                --with-bfd-include-dir=$(binutils_dir1)/bfd/ +               --with-binutils-include-dir=$(binutils_dir)/include/                --target=$(real_gnu_target_name)                --with-libbfd=$(binutils_dir1)/bfd/libbfd.a                --with-libiberty=$(binutils_dir1)/libiberty/libiberty.a \
thorsten, here&#39;s how to apply it....
1) save the patch into ~/download/elf2flt.diff
2) cd ~/buildroot
5) make
hippo, does this patch look allright to you?
will it have any affect on non-debian users?
should something like this go in svn?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14680)</div>
--- Quote End ---
Hootsmon,
I have tested the patch on FC5. The elf2flt works well. Good job.
Could you post the patch to buildroot group of bug report on busybox.net ?
--- Quote Start ---
originally posted by hippo@Apr 28 2006, 12:55 AM
hootsmon,
i have tested the patch on fc5. the elf2flt works well. good job.
could you post the patch to buildroot group of bug report on busybox.net
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14765)
--- quote end ---
--- Quote End ---
Thanks hippo, I&#39;ll post it.
hello!
try to do the patch. saved your code in elf2flt.diff in directory "download".
try to run the given command. here is the result. sorry, did i forgot something
(permissions, line of codes ...)? should i do the cjange by hand?
_____________________________________________________________________
grev@mhfppcx7974note:~/buildroot$ patch -p0 <~/download/elf2flt.diff
patching file toolchain/elf2flt/elf2flt.mk
Hunk# 1 FAILED at 20.
1 out of 1 hunk FAILED -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej
grev@mhfppcx7974note:~/buildroot$ 5~
kind regards torsten
--- Quote Start ---
originally posted by torsten grevsmuehl@May 2 2006, 07:35 PM
hello!
hunk# 1 failed at 20.
1 out of 1 hunk failed -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14937)
--- quote end ---
--- Quote End ---
Add "-l" option to patch command to ignore white space in patch file.
hello hippo! hello hootsmon!
removed all dir. put patch command (with option -l) into buildscript.
let buildscript run like it did the first time.did not observe output of
buildscript nor put it to a file. here the last lines taken from commandline:
~/buildroot/build_nios2/root/usr/bin/uniq -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/unix2dos -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/unzip -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uptime -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uudecode -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uuencode -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/vlock -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/wc -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/wget -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/which -> ../../bin/busybox make: Leaving directory `~/buildroot/build_nios2/busybox&#39;# Just in case chmod a+x  ~/buildroot/build_nios2/root/usr/share/udhcpc/default.script
so everything seems to be in the right place now. is there a quick check
if it is working or should one simply proceed with hippo&#39;s thread?
next: how to keep the things up to date?
kind regards to all involved solving my questions
torsten
