This is a newbie question. Sorry if this is not the right place to post this. I am still using the nios 1 core, waiting on the nios 2. I have an additional module that the nios interfaces with currently and everything seems to work fine. Now what i need is to add an additional control signal to that module so that I can turn on and off certain features from within the nios environment, for example c code with GUI interface to a pc. I am also the cyclone dev kit from altera. So far it doesn't seem like I easily hook up a signal from my extra module directly to the nios without using up one of the proto pins... i must be missing something here. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif thanx for any help on this, -QuanLink Copied
I see the light... I should have read through altera's literature site. It had a document on PIO and that looks like what I was after.
-Quan- Mark as New
<div class='quotetop'>QUOTE </div>
--- Quote Start --- I have an additional module.....[/b] --- Quote End --- Do you interface it with Nios using Avalon BUS?- Mark as New
Yes, i am interfacing it with the avalon bus and it seems to be working okay as expected.
This seems almost too easy. -Quan
Topic Options
