12747 Discussions
jffs2 using part of flash memory
Please see attachment
First pb solved
edit : nodelist.c
change
if (!valid_ref)
by
if (!valid_ref && (f->inocache->ino!=1))
about pb2: jffs2 is a filesystem, so there are some "structs" and "data" to record, to maintain jffs2. So you should not "cover" or "delete" these files.
If you won't to write something on it , follow:
1. copy these files as parts of romfs
2. copy them to jffs2 mtdblock from romfs after succefully mounte it
3. of course, you can copy files to jffs2 block by ftp or nfs.
Anyway, if you got a real image of jffs2 block like PC software "GHOST" dose, named jffs2.image, in my opinion , jffs2.image could be flash-programmed to a new flash , and we get the jffs2 mtdblock simply and directly.
only a "manual" copy may work fine.
Marc
