kernel linker error
Hello, I tried to compile the kernel for a custom board with stratix and 2x16MByte SDRAM.
The linker gives this message:
init/.version.o.d: done.  LD      init/built-in.o  LD      .tmp_vmlinux1 nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text) nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .data) nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .init) nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss) nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .sbss) nios2-elf-ld: section .data overlaps section .text nios2-elf-ld: section .init overlaps section .text make: *** Error 1 make: *** Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
I don't know what this mean. How can I fix it?
