Hello, I tried to compile the kernel for a custom board with stratix and 2x16MByte SDRAM.
The linker gives this message:init/.version.o.d: done.
LD init/built-in.o
LD .tmp_vmlinux1
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .data)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .init)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .sbss)
nios2-elf-ld: section .data overlaps section .text
nios2-elf-ld: section .init overlaps section .text
make: *** Error 1
make: *** Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
I don't know what this mean. How can I fix it?
