Hi everyone,
My problem is still the same as in this thread http://www.alteraforum.com/forum/showthread.php?t=16937 but all the links from there are dead meanwhile, so i'll respawn this here: I build mpeg2dec (from of libmpeg2dec-0.5.1, http://libmpeg2.sourceforge.net/) for nios like this:CC=nios2-linux-uclibc-gcc LDFLAGS=" -elf2flt" ./configure --host=nios2-linux-uclibc --disable-shared --enable-static --without-x --disable-sdl --prefix=/opt/nios2 && make
I build mpeg2dec on my linux-pc like this: ./configure --disable-shared --enable-static --without-x --disable-sdl && make
configuring and compiling seems to work OK in both cases. As Input bitstream i use always this one (gunzipped): http://standards.iso.org/ittf/publiclyavailablestandards/iso_iec_13818-4_2004_conformance_testing/video/bitstreams/main-profile/nokia/nokia_7/nokia7_dual.bit.gz So, my command-line calling mpeg2dec looks like: mpeg2dec -o pgm mnt/nokia7_dual.bit
In both cases (pc and nios) i get (all) four pictures from the mpeg-bitstream decoded. But on the PC Version, the pictures look like expected, while on the NIOS version the pictures look completely destroyed. (see attachments, i used convert from ImageMagick to convert from pgm to jpg) Could anybody be so kind and try this on his/her nios system to see, if mpeg2dec is running with proper output? cheers, WK
链接已复制
7 回复数
I compiled the 'mpeg2dec' for my PC, but it can't decode the beautiful sand art 'Welcome.mpg' of SLS's demo. Of course, I don't know why. www.sls (http://www.%3cb%3esls%3c/b%3e)corp.com/LG/bsp/ug_uclinux_neek_bsp_1.5.pdf KazuHi,
--- Quote Start --- Can you provide a link to the mpeg bitstream? Maybe it's a strange format, which is not recognized by mpeg2dec. --- Quote End --- Please refer the site http://www.slscorp.com/pages/neekbsp.php --- Quote Start --- Are you able to build the mpeg2dec also for a nios system? --- Quote End --- Not yet. Would you tell me the method of compilation? Can we do it only by selecting in the 'menuconfig'? KazuHi,
--- Quote Start --- Please refer the site http://www.slscorp.com/pages/neekbsp.php . --- Quote End --- Hmm, looks like they want some login & password, which i don't have to download anything from there... :( Any other link avaliable? --- Quote Start --- Not yet. Would you tell me the method of compilation? Can we do it only by selecting in the 'menuconfig'? --- Quote End --- I have no idea, wheater it's now in a uCLinux environment. I'm using a pretty old uCLinux, where it was not included (but it looks like my uClinux uses the same gcc: V3.4.6). So i took the tarball directly from the sourceforge link (see my 1st Post, followed "Download" link and took the newest Version 0.5.1) , untarred it (tar -xzvf libmpeg2-0.5.1.tar.gz) and used the mentioned commandline to configure and build it. It doesn't change anything outside its directory if you dont do a "make install". After configuring and building, i just copied the mpeg2dec binary from libmpeg2-0.5.1/src/ to a directory, wich i'm able to access from my nios system via nfs. It's a self designed custum board, doing some MPEG-TS processing on a EP2C35, and it would be a really nice feature, to be able to decode some pictures. Of course it's far from realtime, but a single picture every 10-20 sec or so would be totally sufficient. I've already tried older versions of mpeg2dec and different (also no) optimizations for gcc - result looks always the same. Meanwhile i also build it with a crosscompiler for a coldfire processor, which like nios doesnt have any MMX or SSE extentions - the resulting binary worked fine! I'm getting really confused now... Cheers WKHi,
--- Quote Start --- Hmm, looks like they want some login & password, which i don't have to download anything from there... :( Any other link avaliable? --- Quote End --- Maybe, you can easily resister your e-mail account and get the password from here. http://www.slscorp.com/pages/login.php?login=login_again --- Quote Start --- I have no idea, wheater it's now in a uCLinux environment. I'm using a pretty old uCLinux, where it was not included (but it looks like my uClinux uses the same gcc: V3.4.6). --- Quote End --- It seems that we can select 'libmpeg2' from the menuconfig, so let me see it. KazuHi,
About 'Welcome.mpg', I'm sorry that it includes audio data. So with the switch '-t'
./mpeg2dec -t Welcome.mpg
we can see the beautiful sand art. For Nios CPU, we already have the directory '/uClinux-dist/lib/mpeg2dec', and we can select it from the 'menuconfig'. So.
make menuconfig
Kernel/Library/Defaults Selection ---> <Select>
Customize Application/Library Settings < Exit > < Exit >
Library Configuration ---> <Select>
Build libmpeg2 < Exit > < Exit >
. Before to 'make', please modify the file '/uClinux-dist/lib/mpeg2dec/mpeg2dec-0.4.1/configure' line 23984 like
echo "$as_me:$LINENO: checking if libtool supports -prefer-non-pic flag" >&5
echo $ECHO_N "checking if libtool supports -prefer-non-pic flag... $ECHO_C" >&6
mkdir ac_test_libtool; cd ac_test_libtool; ac_cv_libtool_non_pic=no
echo "int g (int i); static int h (int i) {return g (i);} int f (int i) {return h (i);}" >f.c
echo "int (* hook) (int) = 0; int g (int i) {if (hook) i = hook (i); return i + 1;}" >g.c
../libtool --mode=compile $CC $CFLAGS -prefer-non-pic
-c f.c >/dev/null 2>&1 &&
-c g.c >/dev/null 2>&1 &&
../libtool --mode=link $CC $CFLAGS -prefer-non-pic -o libfoo.la
-rpath / f.lo g.lo >/dev/null 2>&1 &&
ac_cv_libtool_non_pic=yes
cd ..; rm -fr ac_test_libtool; echo "$as_me:$LINENO: result: $ac_cv_libtool_non_pic" >&5
echo "${ECHO_T}$ac_cv_libtool_non_pic" >&6
if test x"$ac_cv_libtool_non_pic" = x"yes"; then
# LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS -prefer-non-pic" <-- line 23984
LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS -fPIC"
else
fi
. (Without this,we have some relocation bugs that is caused the dynamic linking.) After the compilation, you can get 'libmpeg2.so.0' and 'libmpeg2convert.so.0' in '/usr/lib' automatically, but copy 'mpeg2dec' in the directory 'uClinux-dist/lib/mpeg2dec/build/src/.libs' by yourself to the adequate directory e.g. '/usr/bin' with 'nokia7_dual.bit'. And please execute
./mpeg2dec -o pgm nokia7_dual.bit
In my NEEK, the result is fine. Kazu
Moin,
Sorry for the delay, meanwhile i had to do other things. --- Quote Start --- So with the switch '-t'
we can see the beautiful sand art. --- Quote End --- That's good news! --- Quote Start --- (Without this,we have some relocation bugs that is caused the dynamic linking.) --- Quote End --- I think, this is the real problem with "my" mpeg2dec. When i do the change with -fPIC in the configure script, "my" mpeg2dec results look a lot better, but still not error-free. Anyway, now i know, where the problems are. Many thanks for that. What now works ok for me, is a real old mpeg2decoder, which can be downloaded from http://mpeg2videotools.sourceforge.net/ It compiles and runs on my nios system with almost no tweaks; here's a diff of the Makefile, which just changes the gcc and sets the -elf2flt flag during the link: --- mpeg2dec/Makefile 2009-12-21 12:26:24.000000000 +0100
+++ orig/mpeg2dec/Makefile 2003-02-02 17:40:32.000000000 +0100
@@ -43,9 +43,8 @@
# uncomment the following two lines if you want to include X11 support
-#USE_DISP = -DDISPLAY
-#LIBS = -L/usr/X11R6/lib -lX11
-LIBS = -elf2flt
+USE_DISP = -DDISPLAY
+LIBS = -L/usr/X11R6/lib -lX11
# uncomment the following two lines if you want to use shared memory
# (faster display if server and client run on the same machine)
@@ -63,7 +62,7 @@
# GNU gcc
-CC = nios2-linux-uclibc-gcc
+CC = gcc
CFLAGS = -g -O2 $(USE_DISP) $(USE_SHMEM) $(INCLUDEDIR) $(TRACE) $(VERBOSE) $(VE
RIFY) $(WARNINGS)
OBJ = mpeg2dec.o getpic.o motion.o getvlc.o gethdr.o getblk.o getbits.o store.o
recon.o spatscal.o idct.o idctref.o display.o systems.o subspic.o verify.o
Another advantage of the mpeg2decode is, that it can output colored .ppm files, so i don't have to fiddle around with the y and the 2 chroma planes seperatly. Cheers, WK
