make cgi error
dear all,
when i configure the kernal according to hippo, and i make menuconfig ,select the cgi , then save configure.
Miscellaneous Configuration --->
(None) RAMFS Image [ ] generic cgi │ │
│ │ [*] cgihtml │ │
│ │ [ ] SnapGear Button daemon │ │
│ │ [ ] SnapGear Latch daemon │ │
│ │ [ ] SnapGear Morse demo │ │
│ │ [ ] SnapGear R2100 daemon
when i type the :make ,just the fllowing error ,could you help me ! thanks
make[3]: Entering directory `/home/fzh/uClinux-dist-test/user/boa-new/src'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/fzh/uClinux-dist-test/user/boa-new/src'
make[2]: Leaving directory `/home/fzh/uClinux-dist-test/user/boa-new'
make[2]: Entering directory `/home/fzh/uClinux-dist-test/user/busybox'
sh ./mkconfig > .config.tmp
if cmp -s .config.mkconfig .config.tmp ;
then
rm -f .config.tmp ;
else
make clean;
mv -f .config.tmp .config.mkconfig ;
fi
make[2]: Leaving directory `/home/fzh/uClinux-dist-test/user/busybox'
make[2]: Entering directory `/home/fzh/uClinux-dist-test/user/cgihtml/examples'
cd ..; make cgihtml.a
make[3]: Entering directory `/home/fzh/uClinux-dist-test/user/cgihtml'
nios2-linux-uclibc-gcc -Os -g -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/fzh/uClinux-dist-test -fno-builtin -DUNIX -DUPLOADDIR='"/usr/tmp"' -c -o cgi-lib.o cgi-lib.c
cgi-lib.c:181: error: conflicting types for 'getline'
/opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/sys-include/stdio.h:579: error: previous declaration of 'getline' was here
make[3]: *** [cgi-lib.o] Error 1
make[3]: Leaving directory `/home/fzh/uClinux-dist-test/user/cgihtml'
make[2]: *** [../cgihtml.a] Error 2
make[2]: Leaving directory `/home/fzh/uClinux-dist-test/user/cgihtml/examples'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/fzh/uClinux-dist-test/user'
make: *** [subdirs] Error 1
[fzh@localhost uClinux-dist-test
dear all
could you give me how to a websever base boa and cgi ?thanks
--- Quote Start ---
originally posted by nwpu_zhf2004@Jul 9 2006, 10:57 PM
dear all
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16726)
--- quote end ---
--- Quote End ---
You should select,
[*] generic cgi
but not cgihtml
