12748 Discussions
what's this problem when starting linux?
what does it mean by wrong zone alignment? i have a 1M sram to run it, it's not enough?
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
BUG: wrong zone alignment, it will crash
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 16 (order: 4, 256 bytes)
Dentry cache hash table entries: 256 (order: -2, 1024 bytes)
Inode-cache hash table entries: 128 (order: -3, 512 bytes)
Memory available: 88k/1024k RAM, 0k/0k ROM (707k kernel code, 177k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
DMA per-cpu:
cpu 0 hot: low 2, high 6, batch 1
cpu 0 cold: low 0, high 2, batch 1
Normal per-cpu: empty
HighMem per-cpu: empty
Free pages: 0kB (0kB HighMem)
Active:0 inactive:0 dirty:0 writeback:0 unstable:0 free:0 slab:22 mapped:0 paget
ables:0
DMA free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:1024kB pag
es_scanned:0 all_unreclaimable? no
lowmem_reserve[]: 0 0 0
Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pag
HighMem free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pa
ges_scanned:0 all_unreclaimable? no
DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB
0*4096kB = 0kB
Normal: empty
HighMem: empty
Kernel panic - not syncing: Out of memory and no killable processes...
Hi bigmagic,
Probably not. I have a few bare bones images (no network support, few features) an even they
have around 900 KB footprint.
--Scott
hehe, thank u very much, scott. i will try it on another board with a larger sdram.
regards
Hi!
I've found the same problem!
The difference is that I have 2 Mb of RAM, and there's free space, as it shows the init of linux:
Memory available: 292k/2048k RAM, 0k/0k ROM (1404k kernel code, 292k data)
Mi complete init is:
Linux version 2.6.11-uc0 (abg@INDES_ABG) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 16 Fri Jul 7 11:51:48 2006 uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. BUG: wrong zone alignment, it will crash Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 16 (order: 4, 256 bytes) Dentry cache hash table entries: 512 (order: -1, 2048 bytes) Inode-cache hash table entries: 256 (order: -2, 1024 bytes) Memory available: 292k/2048k RAM, 0k/0k ROM (1404k kernel code, 292k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 oom-killer: gfp_mask=0xd0 DMA per-cpu: cpu 0 hot: low 2, high 6, batch 1 cpu 0 cold: low 0, high 2, batch 1 Normal per-cpu: empty HighMem per-cpu: empty
After that, it repeats enledssly the section:
Free pages:          24kB (0kB HighMem) Active:0 inactive:0 dirty:0 writeback:0 unstable:0 free:6 slab:57 mapped:0 pagetables:0 DMA free:24kB min:180kB low:224kB high:268kB active:0kB inactive:0kB present:2048kB pages_scanned:0 all_unreclaimable? no lowmem_reserve: 0 0 0 Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve: 0 0 0 HighMem free:0kB min:128kB low:160kB high:192kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve: 0 0 0 DMA: 0*4kB 1*8kB 1*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 24kB Normal: empty HighMem: empty oom-killer: gfp_mask=0xd0 DMA per-cpu: cpu 0 hot: low 2, high 6, batch 1 cpu 0 cold: low 0, high 2, batch 1 Normal per-cpu: empty HighMem per-cpu: empty
I thought that 2 MB was enough, so I don't think the RAM size is the problem... any idea?
Alex
it is out of memory.
you should have at least 8M sdram to run some apps on uclinux.
