make error!Can you help me ?
Hi,everybody.I encountered a error as the following when i compilered the uclinux kernel. I followed the steps like:
http://www.nioswiki.com/installnios2linux
My OS is ubuntu10.04
gcc is 4.2
Platform is DE2_70
Could anybody help to fix it,
Thanks.:)
LD usr/built-in.o
{standard input}: Assembler messages:
{standard input}:96: Error: unrecognised instruction flushda
{standard input}:232: Error: unrecognised instruction flushda
{standard input}:365: Error: unrecognised instruction flushda
{standard input}:428: Error: unrecognised instruction flushda
make[3]: *** [arch/nios2/mm/memory.o] 错误 1
LD arch/nios2/drivers/built-in.o
make[2]: *** [arch/nios2/mm] 错误 2
make[2]: *** 正在等待未完成的任务....
make[2]: *** wait: 没有子进程。 停止。
make[1]: *** [sub-make] 错误 2
make[1]:正在离开目录 `/usr/local/src/nios2-linux/linux-2.6'
make: *** [linux] 错误 1
How can I fix it,Can you help me ? Thank you.
Its the version of your compiler gcc 4.0 or its older?
there is some link about it http://bbs.socvista.com/viewthread.php?tid=3546&page=1&styleid=3
Cándido
