Hi,everybody.I encountered a error as the following when i compilered the uclinux kernel. I followed the steps like:
http://www.nioswiki.com/installnios2linux My OS is ubuntu10.04 gcc is 4.2 Platform is DE2_70 Could anybody help to fix it, Thanks.:) ---------------------------------------------------------- LD usr/built-in.o {standard input}: Assembler messages: {standard input}:96: Error: unrecognised instruction flushda {standard input}:232: Error: unrecognised instruction flushda {standard input}:365: Error: unrecognised instruction flushda {standard input}:428: Error: unrecognised instruction flushda make[3]: *** [arch/nios2/mm/memory.o] 错误 1 LD arch/nios2/drivers/built-in.o make[2]: *** [arch/nios2/mm] 错误 2 make[2]: *** 正在等待未完成的任务.... make[2]: *** wait: 没有子进程。 停止。 make[1]: *** [sub-make] 错误 2 make[1]:正在离开目录 `/usr/local/src/nios2-linux/linux-2.6' make: *** [linux] 错误 1 How can I fix it,Can you help me ? Thank you.Link Copied
Its the version of your compiler gcc 4.0 or its older? there is some link about it http://bbs.socvista.com/viewthread.php?tid=3546&page=1&styleid=3 Cándido- Mark as New
please install the binary toolchain,
http://www.nioswiki.com/operatingsystems/uclinux/binarytoolchain ftp://ftp.altera.com/outgoing/nios2gcc-20080203.tar.bz2 http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2 http://sopc.et.ntust.edu.tw/pub/gnutools/nios2gcc-20080203.tar.bz2 ftp://sopc.et.ntust.edu.tw/pub/gnutools/nios2gcc-20080203.tar.bz2 - Hippo
