12745 ディスカッション
make_flash_image_script.sh error
名誉コントリビューター II
2,483件の閲覧回数
Hi all,
I use advanced_boot_copier of Altera, I try to make software image with make_flash_image_script. I put make_flash_image_script.sh, make_header.pl, read_flash_image.pl files into the same folder as elf file and run script from Nios2 Command Shell GCC 4 (Version 15.0, build 145). But there is no srec file after script executing.
The text of warning:
BFD: factory.elf.tmp.elf: warning: Empty loadable segment detected, is this intentional?
./make_flash_image_script.sh: line 156: conv: command not found.
I have no idea how i can resolve this. Please, help.
0 件の賞賛
2 返答(返信)
名誉コントリビューター II
1,467件の閲覧回数
I found a solution.
It's working with gcc3. I use Command Shell of Quartus 11.1 and script works.
IMS
初心者
1,421件の閲覧回数
this file uses an outdatet gcc3 function "conv".
I changed the code from:
conv -D  $fake_copier ;
To:
 iconv -c -s $fake_copier ;
Now it will use a function from gcc4 and should work well for your purpose.
返信
