make romfs
Hi ,
error while giving "make romfs",
The Detailed explanations as follows ......
[root@localhost uClinux-dist]# make romfs
rm -f /usr/Vivek/uclinuxvivek/uClinux-dist/images/romfs-inst.log
for dir in vendors include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu -C $dir romfs || exit 1 ; done
make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors'
make -C /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu/. -f /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/vendors-common.mak romfs
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu'
[ -d /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i ] || mkdir -p /usr/Vivek/uclinuxvivek/uClinux-dist/romfs
for i in bin sbin dev etc home lib mnt proc usr var sys tmp etc/config etc/default etc/dhcpc home/ftp home/httpd home/httpd/cgi-bin usr/bin usr/sbin usr/share /usr/share/udhcpc; do
[ -d /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i ] || mkdir -p /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i;
done
chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/tmp
chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/home/ftp
romfs-inst.sh ../../Generic/romfs /
24 blocks
romfs-inst.sh -s /bin/init /init
romfs-inst.sh /etc/inittab
romfs-inst.sh /etc/rc
romfs-inst.sh /etc/TZ
romfs-inst.sh /etc/passwd
romfs-inst.sh /etc/group
romfs-inst.sh /etc/hosts
romfs-inst.sh /etc/host.conf
romfs-inst.sh /etc/ftpwelcome
romfs-inst.sh /etc/ftpusers
romfs-inst.sh /etc/boa.conf
romfs-inst.sh /etc/mime.types
romfs-inst.sh /usr/share/udhcpc/default.script
chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/usr/share/udhcpc/default.script
echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/etc/version
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu'
make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors'
make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include'
make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/lib'
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/passwd /etc/passwd
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/group /etc/group
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/mtab /etc/mtab
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/fstab /etc/fstab
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/resolv.conf /etc/resolv.conf
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow
for i in /usr/Vivek/uclinuxvivek/uClinux-dist/prop ; do
[ ! -d $i ] || make -C $i romfs || exit $? ;
done
make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/lib'
make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user'
for i in busybox cgi_generic debug dhcpcd-new ftp ftpd games inetd init ramimage sash telnetd /usr/Vivek/uclinuxvivek/uClinux-dist/prop ; do
done
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/busybox'
if [ -f "$ROMFSDIR/bin/busybox" ]; then
inode=`ls -i $ROMFSDIR/bin/busybox | awk '{print $1}'`;
ls -iL "$ROMFSDIR/bin" | grep "^ *$inode" | awk '{print $2}' |
sed "s:^:$ROMFSDIR/bin/:" | env -i xargs rm -f;
fi
romfs-inst.sh /bin/busybox
/bin/sh install-romfs.sh /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/ --nosubdir
/usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/halt -> busybox
/usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/poweroff -> busybox
/usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/reboot -> busybox
/usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/mesg -> busybox
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/busybox'
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/cgi_generic'
romfs-inst.sh /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Generic/httpd /home/httpd
2 blocks
romfs-inst.sh /home/httpd/cgi-bin/cgi_demo
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/cgi_generic'
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/debug'
romfs-inst.sh /bin/debug
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/debug'
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/dhcpcd-new'
romfs-inst.sh /bin/dhcpcd
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/dhcpcd-new'
make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp'
for i in ftp ; do make -C $i romfs ; done
make[3]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp/ftp'
romfs-inst.sh /bin/ftp
cp: cannot stat `ftp': No such file or directory
make[3]: *** [romfs] Error 1
make[3]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp/ftp'
make[2]: *** [romfs] Error 2
make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp'
make[1]: *** [romfs] Error 2
make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user'
make: *** [romfs.subdirs] Error 1
And what about busy box error ?
:ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r:
Thanks and Regards
Vivek....
I'm also experiencing this same problem. I'm trying to recompile the kernel on the uClinux to embedded on the Altera DE2 board, but in step make romfs displays the error.
lenardocs@coyote:~/Download/uClinux-dist$ make romfs
rm -f /home/lenardocs/Download/uClinux-dist/images/romfs-inst.log
make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/vendors'
make -C /home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu/. -f /home/lenardocs/Download/uClinux-dist/vendors/vendors-common.mak romfs
make[2]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu'
[ -d /home/lenardocs/Download/uClinux-dist/romfs/$i ] || mkdir -p /home/lenardocs/Download/uClinux-dist/romfs
[ -d /home/lenardocs/Download/uClinux-dist/romfs/$i ] || mkdir -p /home/lenardocs/Download/uClinux-dist/romfs/$i;
done
chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/tmp
chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/home/ftp
24 bloqueios
chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/usr/share/udhcpc/default.script
echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /home/lenardocs/Download/uClinux-dist/romfs/etc/version
make[2]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu'
make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/vendors'
make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/include'
make[1]: Nada a ser feito para `romfs'.
make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/include'
make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/lib'
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/hosts /etc/hosts
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_BASH_BASH -s config/profile /etc/profile
for i in ; do
done
make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/lib'
make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user'
for i in boa busybox cgi_generic debug dhcpcd-new ftp ftpd games inetd init sash telnetd /home/lenardocs/Download/uClinux-dist/prop ; do
done
make[2]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: impossível obter estado de `boa': Arquivo ou diretório não encontrado
make[3]: ** [romfs] Erro 1
make[3]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user/boa/src'
make[2]: ** [romfs] Erro 2
make[2]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user/boa'
make[1]: ** [romfs] Erro 2
make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user'
make: ** [romfs.subdirs] Erro 1
Could anyone suggest me how should I proceed? I am grateful for the suggestions. Thank you.
http://www.google.com/images/cleardot.gif
