Hi ,
error while giving "make romfs", The Detailed explanations as follows ...... [root@localhost uClinux-dist]# make romfs rm -f /usr/Vivek/uclinuxvivek/uClinux-dist/images/romfs-inst.log for dir in vendors include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu -C $dir romfs || exit 1 ; done make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors' make -C /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu/. -f /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/vendors-common.mak romfs make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu' [ -d /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i ] || mkdir -p /usr/Vivek/uclinuxvivek/uClinux-dist/romfs for i in bin sbin dev etc home lib mnt proc usr var sys tmp etc/config etc/default etc/dhcpc home/ftp home/httpd home/httpd/cgi-bin usr/bin usr/sbin usr/share /usr/share/udhcpc; do [ -d /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i ] || mkdir -p /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/$i; done chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/tmp chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/home/ftp romfs-inst.sh ../../Generic/romfs / 24 blocks romfs-inst.sh -s /bin/init /init romfs-inst.sh /etc/inittab romfs-inst.sh /etc/rc romfs-inst.sh /etc/TZ romfs-inst.sh /etc/passwd romfs-inst.sh /etc/group romfs-inst.sh /etc/hosts romfs-inst.sh /etc/host.conf romfs-inst.sh /etc/ftpwelcome romfs-inst.sh /etc/ftpusers romfs-inst.sh /etc/boa.conf romfs-inst.sh /etc/mime.types romfs-inst.sh /usr/share/udhcpc/default.script chmod 777 /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/usr/share/udhcpc/default.script echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/etc/version make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Altera/nios2nommu' make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/vendors' make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include' make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/lib' romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/passwd /etc/passwd romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/group /etc/group romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/mtab /etc/mtab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/fstab /etc/fstab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/resolv.conf /etc/resolv.conf romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow for i in /usr/Vivek/uclinuxvivek/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/lib' make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/include' make[1]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user' for i in busybox cgi_generic debug dhcpcd-new ftp ftpd games inetd init ramimage sash telnetd /usr/Vivek/uclinuxvivek/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/busybox' if [ -f "$ROMFSDIR/bin/busybox" ]; then inode=`ls -i $ROMFSDIR/bin/busybox | awk '{print $1}'`; ls -iL "$ROMFSDIR/bin" | grep "^ *$inode" | awk '{print $2}' | sed "s:^:$ROMFSDIR/bin/:" | env -i xargs rm -f; fi romfs-inst.sh /bin/busybox /bin/sh install-romfs.sh /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/ --nosubdir /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/halt -> busybox /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/poweroff -> busybox /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/reboot -> busybox /usr/Vivek/uclinuxvivek/uClinux-dist/romfs/bin/mesg -> busybox make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/busybox' make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/cgi_generic' romfs-inst.sh /usr/Vivek/uclinuxvivek/uClinux-dist/vendors/Generic/httpd /home/httpd 2 blocks romfs-inst.sh /home/httpd/cgi-bin/cgi_demo make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/cgi_generic' make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/debug' romfs-inst.sh /bin/debug make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/debug' make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/dhcpcd-new' romfs-inst.sh /bin/dhcpcd make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/dhcpcd-new' make[2]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp' for i in ftp ; do make -C $i romfs ; done make[3]: Entering directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp/ftp' romfs-inst.sh /bin/ftp cp: cannot stat `ftp': No such file or directory make[3]: *** [romfs] Error 1 make[3]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp/ftp' make[2]: *** [romfs] Error 2 make[2]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user/ftp' make[1]: *** [romfs] Error 2 make[1]: Leaving directory `/usr/Vivek/uclinuxvivek/uClinux-dist/user' make: *** [romfs.subdirs] Error 1 [root@localhost uClinux-dist]# And what about busy box error ? ............................................................ :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: Thanks and Regards Vivek....Link Copied
I'm also experiencing this same problem. I'm trying to recompile the kernel on the uClinux to embedded on the Altera DE2 board, but in step make romfs displays the error.
lenardocs@coyote:~/Download/uClinux-dist$ make romfs
rm -f /home/lenardocs/Download/uClinux-dist/images/romfs-inst.log for dir in vendors include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu -C $dir romfs || exit 1 ; done make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/vendors' make -C /home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu/. -f /home/lenardocs/Download/uClinux-dist/vendors/vendors-common.mak romfs make[2]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu' [ -d /home/lenardocs/Download/uClinux-dist/romfs/$i ] || mkdir -p /home/lenardocs/Download/uClinux-dist/romfs for i in bin sbin dev etc home lib mnt proc usr var sys tmp etc/config etc/default etc/dhcpc home/ftp home/httpd home/httpd/cgi-bin usr/bin usr/sbin usr/share /usr/share/udhcpc; do [ -d /home/lenardocs/Download/uClinux-dist/romfs/$i ] || mkdir -p /home/lenardocs/Download/uClinux-dist/romfs/$i; done chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/tmp chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/home/ftp romfs-inst.sh ../../Generic/romfs / 24 bloqueios romfs-inst.sh -s /bin/init /init romfs-inst.sh /etc/inittab romfs-inst.sh /etc/rc romfs-inst.sh /etc/TZ romfs-inst.sh /etc/passwd romfs-inst.sh /etc/group romfs-inst.sh /etc/hosts romfs-inst.sh /etc/host.conf romfs-inst.sh /etc/ftpwelcome romfs-inst.sh /etc/ftpusers romfs-inst.sh /etc/boa.conf romfs-inst.sh /etc/mime.types romfs-inst.sh /usr/share/udhcpc/default.script chmod 777 /home/lenardocs/Download/uClinux-dist/romfs/usr/share/udhcpc/default.script echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /home/lenardocs/Download/uClinux-dist/romfs/etc/version make[2]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/vendors/Altera/nios2nommu' make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/vendors' make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/include' make[1]: Nada a ser feito para `romfs'. make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/include' make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/lib' romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/passwd /etc/passwd romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/group /etc/group romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/mtab /etc/mtab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/fstab /etc/fstab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/hosts /etc/hosts romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/resolv.conf /etc/resolv.conf romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_BASH_BASH -s config/profile /etc/profile romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow for i in ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/lib' make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/include' make[1]: Nada a ser feito para `romfs'. make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/include' make[1]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user' for i in boa busybox cgi_generic debug dhcpcd-new ftp ftpd games inetd init sash telnetd /home/lenardocs/Download/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entrando no diretório `/home/lenardocs/Download/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: impossível obter estado de `boa': Arquivo ou diretório não encontrado make[3]: ** [romfs] Erro 1 make[3]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user/boa/src' make[2]: ** [romfs] Erro 2 make[2]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user/boa' make[1]: ** [romfs] Erro 2 make[1]: Saindo do diretório `/home/lenardocs/Download/uClinux-dist/user' make: ** [romfs.subdirs] Erro 1 Could anyone suggest me how should I proceed? I am grateful for the suggestions. Thank you. http://www.google.com/images/cleardot.gif
