mcp2515 SPI-CAN interfacing
nitin123
초급자
455 조회수
I'm currently working on interfacing the MCP2515 CAN controller with a Nios II processor via SPI. While I can observe SPI transactions on a logic analyzer, I'm not receiving any responses from the MCP2515.
Has anyone successfully interfaced the MCP2515 with a Nios II processor? If so, could you share insights or code snippets that might help identify what might be going wrong in my setup?
Any guidance or suggestions would be greatly appreciated.
Thank you!
this is my code :
/* Bit Timing for 8MHz crystal @1Mbps */
#define CNF1_VAL 0x03 // BRP=3 (TQ=1µs)
#define CNF2_VAL 0x90 // PHSEG1=3, PRSEG=1
#define CNF3_VAL 0x02 // PHSEG2=3
/* SPI Command Helper Functions */
static void write_reg(uint8_t addr, uint8_t value) {
uint8_t tx_buf[3] = {MCP_WRITE, addr, value};
alt_avalon_spi_command(SPI_BASE, SPI_SLAVE, 3, tx_buf, 0, NULL, 0);
static uint8_t read_reg(uint8_t addr) {
uint8_t tx_buf[3] = {MCP_READ, addr, 0xFF};
uint8_t rx_buf[3] = {0};
alt_avalon_spi_command(SPI_BASE, SPI_SLAVE, 3, tx_buf, 3, rx_buf, ALT_AVALON_SPI_COMMAND_MERGE);
return rx_buf[2];
/* Initialization */
int mcp2515_tx_init(void) {
DBG("Initializing MCP2515...\n");
/* 1. Software Reset */
uint8_t reset_cmd = MCP_RESET;
alt_avalon_spi_command(SPI_BASE, SPI_SLAVE, 1, &reset_cmd, 0, NULL, 0);
alt_busy_sleep(15000); // 5ms delay
/* 2. Enter Configuration Mode */
write_reg(CANCTRL, 0x80);
alt_busy_sleep(100);
/* Verify Configuration Mode */
uint8_t mode = read_reg(CANSTAT) & 0xE0;
if(mode != 0x80) {
DBG("Config Mode Fail: 0x%02X\n", mode);
return -1;
/* Configure TXRTSCTRL (disable RTS functionality) */
write_reg(0x0D, 0x00); // TXRTSCTRL = 0 (digital inputs)
/* 3. Set Bit Timing */
write_reg(CNF1, CNF1_VAL);
write_reg(CNF2, CNF2_VAL);
write_reg(CNF3, CNF3_VAL);
DBG("CNF1=0x%02X, CNF2=0x%02X, CNF3=0x%02X\n",
read_reg(CNF1), read_reg(CNF2), read_reg(CNF3));
/* 4. Return to Normal Mode */
write_reg(CANCTRL, 0x00);
/* Verify Normal Mode */
if(mode != 0x00) {
DBG("Normal Mode Fail: 0x%02X\n", mode);
return -1;
DBG("MCP2515 Ready\n");
return 0;
/* CAN Frame Transmission */
static void transmit_frame(uint16_t can_id, uint8_t *data, uint8_t dlc) {
/* Check if TXREQ is clear (buffer is free) */
uint8_t txb0ctrl = read_reg(0x30); // Read TXB0CTRL
if (txb0ctrl & 0x08) { // TXREQ bit is set
DBG("TXB0 busy! Aborting...\n");
return;
uint8_t tx_buffer[13] = {
MCP_WRITE,
0x31, // Start at TXB0SIDH
(uint8_t)(can_id >> 3), // SIDH
(uint8_t)((can_id & 0x07) << 5), // SIDL
0x00, // EID8
0x00, // EID0
(dlc & 0x0F), // DLC
// Data starts at TXB0D0 (0x36)
0x36 // TXB0D0 address (auto-increment)
memcpy(&tx_buffer[7], data, dlc); // Copy data bytes
// Single transaction for header + data
alt_avalon_spi_command(SPI_BASE, SPI_SLAVE, 7 + dlc, tx_buffer, 0, NULL, 0);
// Trigger transmission
uint8_t txreq_cmd[] = {MCP_WRITE, 0x30, 0x08}; // Set TXREQ
alt_avalon_spi_command(SPI_BASE, SPI_SLAVE, 3, txreq_cmd, 0, NULL, 0);
/* Continuous Transmission */
void mcp2515_continuous_tx(void) {
uint8_t data[8] = {0x69}; // Test data
DBG("Starting CAN Transmission\n");
while(1) {
transmit_frame(0x100, data, 1);
alt_busy_sleep(10000); // 10ms delay
int main(void) {
if(mcp2515_tx_init() != 0) return -1;
mcp2515_continuous_tx();
return 0;
레이블 (1)
0 포인트
3 응답
SueC_Altera
직원
401 조회수
Hi Nitin123,
This seems to be a duplicate of your question on an old post https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/MCP2515-CANbus-implementation-in-NIOS-using-alt-avalon-spi/m-p/252560#M48085
Since the discussion has been started on that thread, let's mark this one as answered/duplicate so that we keep the discussion in one place.  Is that ok with you?
Sue
0 포인트
BoonBengT_Altera
중재자
349 조회수
Hi @nitin123,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Hope to hear from you soon.
Best Wishes
BB
0 포인트
BoonBengT_Altera
중재자
292 조회수
Hi @nitin123,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
0 포인트
응답
