mmc/sd problem
Hi all,
I have generated a uclinux kernel for my custom board. The SD card driver is bast on SPI bus, with 20MHz bus clock. (According to http://www.alterawiki.com/wiki/mmcsd).
I can operate the SD card well after I mount it to /mnt. However, I met a problem. If I umount the SD card, and pop-push it, a Error will come out. I list it at the tail of this thread.
The case remains even if I change the SPI bus clock to 100KHz. Could somebody help me, please...
Derek
"mmcblk0: retrying using single block read
mmcblk0: error -110 sending status comand<3>mmcblk0: error -110 sending read/wri
te command, response 0x0, card status 0x0
end_request: I/O error, dev mmcblk0, sector 103
end_request: I/O error, dev mmcblk0, sector 104
EXT3-fs: unable to read superblock
end_request: I/O error, dev mmcblk0, sector 101
FAT: unable to read boot sector
mount: mounting /dev/mmcblk0p1 on /mnt failed: Input/output error"
Supposedly the driver is not notified by the hardware that the card has been unpowered and needs re-initialization. e.g. the NEEK lacks the appropriate hardware for this. I suppose a dedicated i/O is necessary on that behalf.
When playing with the SD-Card I needed to unload and re-load the driver to re-initialize a re-inserted card.
-Michael
I get it. Thank you, Michael.
