modifying ghrd_top.v
I have a Cyclone V SOC Dev kit. I can copy the golden hardware design to temp and build it.
I open qsys and add a Uart 232 hook it up then generate the code with no errors.
I go to the pin planner and I don’t see the txd or rxd.
How do I re-generate the ghrd_top.v?
If I remove say the push button object it stays in the ghrd_top.v.
So do I modify the ghrd_top.v manually?
Thanks in advance
Piglet
