mount text file
MusGer
Hi there;
It is possible to  mount text file using normal run mode, nonetheless we can read write of text under debugging mode only ??
thanks in advance your contribution
Regards .
EBERLAZARE_I_Intel
I am not sure what you are trying to achieve, is it copying the output to a text file (.txt)?
MusGer
Thanks for ur respond,
I try to copy a chunk of enormous dataset that stored in host computer with extension (txt) file to complete computations using soft-processor.
I hope you get my point, and appreciate your support.
EBERLAZARE_I_Intel
Here is the debugging steps:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/debugging-the-nios-ii-software-running.html
I am unaware to mount to a .txt file that you are trying to achieve.
Maybe you could check this thread discussion a text file exports:
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/How-to-save-Nios-II-console-contents/m-p/212548
EBERLAZARE_I_Intel
Could you check my previous respond?
