12747 ディスカッション
my first fpga hps
名誉コントリビューター II
3,054件の閲覧回数
Im just trying to run my_first_hps_fpga but when I try to make in the shell there is an error
I dont get where is the problem
pleaase help me
there is an attachement.
0 件の賞賛
5 返答(返信)
名誉コントリビューター II
1,725件の閲覧回数
Sorry the forum automatically reduced your image and the error message is unreadable. Please either paste the text in the forum or use another format than jpeg.
名誉コントリビューター II
1,725件の閲覧回数
yes , when I launch make
arm-linux-gnueabihf-gcc-static-g-wall -I/ip/altera/hps/altera_hps/hwlib/include -c main.c -o-main.o
process began :create Process<NULL, arm-linux-gnueabihf-gcc-static-g-wall -I/ip/altera/hps/altera_hps/hwlib/include -c main.c -o-main.o ---> failed
the error was : make <e=2> the system cannot find the file specified .
Itry to run the project in DEmonstrations SOC-fpga-my first _hps_fpga flowing the same steps like this project :https://www.youtube.com/watch?v=2wuket4-q7q
thank u
名誉コントリビューター II
1,725件の閲覧回数
The name of the comiler command is arm-linux-gnueabihf-gcc, so I wonder if you are missing some spaces in your makefile. Do you really have arm-linux-gnueabihf-gcc-static-g-wall without any spaces? -static and "-g -Wall" (with a capital W) are also options that should be separated with spaces.
Could you show your makefile?
名誉コントリビューター II
1,725件の閲覧回数
yeaah Im just put the commnd make and it automatically generated
MY operating system is windows 8.1
Should I have linux to do this in my laptop ?
MY MAKE FILE
TARGET = my_first_hps-fpga
CROSS_COMPILE = arm-linux-gnueabihf-
CFLAGS = -static -g -Wall -I${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib/include
LDFLAGS = -g -Wall
CC = $(CROSS_COMPILE)gcc
ARCH= arm
build: $(TARGET)
$(TARGET): main.o
$(CC) $(LDFLAGS) $^ -o $@
%.o : %.c
$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
rm -f $(TARGET) *.a *.o *~
名誉コントリビューター II
1,725件の閲覧回数
No you don't need linux, as long as you are using the SOC EDS shell it should work fine. Could you check out if SOCEDS_DEST_ROOT is set correctly in the shell? just write:
echo $SOCEDS_DEST_ROOT
返信
