12748 Discussions
need help in c code for communication between Nios ii processor and custom component.
hi ,
i am done with my qsys design . now i want to move to the next steps. i wan to send data from my nios II processor to the custom Component ( encoder) , i created. can any one suggest me any example codes. i need to send a 32 bit data to the custom component from nios II processor. please do suggest me ...
add 32 bit PIO from u r qsys (i haven't much idia about qsys, i am using SOPC builder) , and write u r data on this bus using u r c- code,
don't forget to add this 32 bus to u r nios-ii symbol.
http://www.akiron.com/fpga/customipinstruction.pdf
this is my note.
it is written for SOPC builder.
Qsys changed a lot of appearance.
but the idea is basically same.
should work.
Maybe you can memory map to address and r/w from that or use pio
i am asking can anyone give me a C code for communication from nios II processor to some custom block i created. i am done with qsys. it is compiled. no issues. please do help with the c code
ho about
///////////////////////// c code (^v^ )/////////////////////////////////////////
# include <io.h>
# include <system.h>
short pio_button;
pio_button = IORD_16DIRECT(PIO_BUTTON_BASE,0);
IOWR_16DIRECT(PIO_LED_BASE,0,pio_button);
IORD_16DIRECT is reading register from address of PIO_BUTTON_BASE
IOWR_16DIRECT is writing data to PIO_LED_BASE
those base addresses are written in <system.h>
serch IOWR_*DIRECT functions
