nfs-problem
if i try to mount an nfs-share like:
mount -t nfs 10.10.13.118:/data1 /mnt/nfs -n -o nolock
i get the following error:
nfs warning: mount version older than kernel
if i try to list the dir with ls it works but if i copy a file from /mnt/nfs to my CF-Card /mnt/ide0
i get an other error like:
(it takes a long time then)
nfs: server 10.10.13.118 not responding, still trying
i searched the forum and see a thread that describe the same error but must i have portmap to do this??
My nfs server is a Suse Linux 9.3 professionell Worksation.
/etc/exports
/data1 *(rw,no_auth_nlm,insecure_locks,no_acl,no_root_squash)
hope someone can help
regards
Mike
Hi all,
i browse the Source code of the linux distri und i looked on this:
Usage Notes
- this version of mount/umount was taken from Slackware v8.1 and ported over
to work with uClinux 2.4.x
- In the original version of mount/umount, the etc/mtab and etc/fstab files
were never referenced (by default)
is this the reason why nfs do not work with suse 9.3 ??
I tested Suse 8.2 with Kernel 2.4 and it works fine but we want to use Suse9.3 on ouer server.
Is there any workaround to get them work?
Must i make a new mount command ?
regards
Mike http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
You can try the busybox mount command... to do this you need to include busybox into your filesystem project re-build and re-upload.
Once you&#39;ve logged in, run
busybox mount <options>
That might help but I don&#39;t think it&#39;s the mount program that&#39;s the problem...
What type of network adapter are you using on your Nios II board?
Hello Ken,
i used a Cyclone I developmentboard from Altera and a Cyclone II developmentboard from Altera.
On the boards the same networkcard smc lan911c111.
It tells me the error:
nfs warning: mount version older than kernel http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
I tested the mount command from busybox and it works. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
I use Quartus 5.0Sp1 Nios II 5.0 and uClinux 1.4, Nios developmentboard Cyclone II EPC2S35 from Altera;
NFS-Server with bordcomm Gigabit network card and Suse 9.3 (it works with all other applications)
I think its the normal mount command that not work with new nfs-servers.
Yesterday i logged the traffic on the network to see whats wrong. The Suse server send all the packets but the Nios
always want a reply from all packets.
regards
Mike
