if i try to mount an nfs-share like: mount -t nfs 10.10.13.118:/data1 /mnt/nfs -n -o nolock i get the following error: nfs warning: mount version older than kernel if i try to list the dir with ls it works but if i copy a file from /mnt/nfs to my CF-Card /mnt/ide0 i get an other error like: (it takes a long time then) nfs: server 10.10.13.118 not responding, still trying i searched the forum and see a thread that describe the same error but must i have portmap to do this?? My nfs server is a Suse Linux 9.3 professionell Worksation. /etc/exports /data1 *(rw,no_auth_nlm,insecure_locks,no_acl,no_root_squash) hope someone can help regards MikeLink Copied
Hi all,
i browse the Source code of the linux distri und i looked on this: Usage Notes ----------- - this version of mount/umount was taken from Slackware v8.1 and ported over to work with uClinux 2.4.x - In the original version of mount/umount, the etc/mtab and etc/fstab files were never referenced (by default) is this the reason why nfs do not work with suse 9.3 ?? I tested Suse 8.2 with Kernel 2.4 and it works fine but we want to use Suse9.3 on ouer server. Is there any workaround to get them work? Must i make a new mount command ? regards Mike http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif- Mark as New
You can try the busybox mount command... to do this you need to include busybox into your filesystem project re-build and re-upload.
Once you've logged in, run busybox mount <options> That might help but I don't think it's the mount program that's the problem... What type of network adapter are you using on your Nios II board?- Mark as New
Hello Ken,
i used a Cyclone I developmentboard from Altera and a Cyclone II developmentboard from Altera. On the boards the same networkcard smc lan911c111. It tells me the error: nfs warning: mount version older than kernel http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif I tested the mount command from busybox and it works. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif I use Quartus 5.0Sp1 Nios II 5.0 and uClinux 1.4, Nios developmentboard Cyclone II EPC2S35 from Altera; NFS-Server with bordcomm Gigabit network card and Suse 9.3 (it works with all other applications) I think its the normal mount command that not work with new nfs-servers. Yesterday i logged the traffic on the network to see whats wrong. The Suse server send all the packets but the Nios always want a reply from all packets. regards Mike
