nios terminal error
when I start up the nios terminal in nios SDK by entering the command nios_terminal, there is a message shown as "the JTAG cable you are using is not supported for NiosII system, you may experience intermittent JTAG failure with this cable. Please use a USB Blaster revision B cable and other supported cable".
when I use a USB Blaster revision B cable, it still the same. what shall I do? Thank you
