can someone help me with the following problem:
I'm trying to build a uClinux for a custom board. To do this i followed the next steps out of this tutorial: http://www.mail-archive.com/linuxkernelnewbies@googlegroups.com/msg01853.html But when I'm in the MENU i don't see the NiosII FPGA configuration, can somebody tell me what I'm doing wrong? ThanksLink Copied
Isn't there anyone who can help me?
I tried it multiple times, also whit the niosII_cycloneIII_3c120 project described in the tutorial... But i never get the Nios II configuration option- Mark as New
Vendor+product look fine in the first screenshot. Select "Customize kernel" and exit to get to the rest of the configuration.
The second image in your post is not showing up.- Mark as New
Thank you for your response...
I tried it ones more with your advice, and i managed to get into the "NiosII configuration". I don't know what i did different this time, i think that i forgot the save the .config file. But i now can access the configuration settings. Thanks a can for your help, now i can go further with my tutorial...
Topic Options
