no boot over nfs
Hello!
My configuration worked well with initramfs. Now i like to boot over NFS. I did everything like in "NFSFileSystem" and I can mount the NFS in the linux booted with initramfs. Further I had to enabled in Networking "IP: kernel level autoconfiguration" and Network File Systems "Root file system on NFS" to get the system booting over nfs.
First I had an error like "can not open initial console" because "/dev" was empty. So I created the device nodes defined in "romfs_list".
Now I have the following error:
IP-Config: Complete: device=eth0, addr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255, host=nios2, domain=, nis-domain=(none), bootserver=192.168.1.2, rootserver=192.168.1.2, rootpath= Looking up port of RPC 100003/2 on 192.168.1.2 Looking up port of RPC 100005/1 on 192.168.1.2 VFS: Mounted root (nfs filesystem). Freeing unused kernel memory: 56k freed (0x176000 - 0x183000) Kernel panic - not syncing: Attempted to kill init!
When I trac the traffic with wireshark, I can see that "rc" is executed and "inittab" (which is empty) is called. After that call the traffic stops followed by an ARP.
can anybody help me?
Hi!
If I add the line "ttyS0:vt100:/bin/sh" to the inittab I get a console and no Kernel panic anymore. But the welcome screen from rc (/etc/motd) is not shown.
When I boot with initramfs, inittab is empty but I still get a console and the welcome screen is shown. I use the normal UART and not the JTAG UART.
Do i have to set the std_out somewhere?
Or has anybody an other idea?
thanks for your help!
glattchr
which console device do you use ? jtag or rs232?
In kernel menuconfig, you should select either jtag uart or serial uart for console device (but not both).
Device Drivers ---> Character devices ---> Serial drivers --->
if you use jtag uart (with a USB Blaster cable) on a nios2-terminal,
[ ] Nios serial support
[*] Altera JTAG UART support
[*] Support for console on Altera JTAG UART
if you use serial uart (with a 9-pin RS-232C cable) on a terminal emulator such as minicom or ckermit,
[*] Nios serial support
[*] Support for console on Nios UART
[ ] Altera JTAG UART support
The console device will use /dev/console node.
Yes, you need to create all /dev nodes or copy them from initamfs.
Do you get the shell prompt?
I tried again nfsroot and updated the NFS wiki page. Please check.
Hello Hippo
Thanks for your help!
I disabled the sysfs support as you told me. I had both UARTs enabled in the Nios, but only the "normal" (not JTAG) in the kernel. After recomiling the Nios with only one UART, I got the "welcome screen" also when booting over NFS. But with the empty inittab, I've got still a kernel panic, with the "ttyS0:vt100:/bin/sh" line, it works.
Do you know if the initramfs does some further initialisation which I don't get when boot over NFS?
best regards
glattchr
Yes, you should not enable both jtag and uart as "support for console" in kernel config.
You should choose only one of them. see the wiki,
http://nioswiki.jot.com/wikihome/operating...nux/linuxconfig (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxconfig
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
[ ] Altera JTAG UART support[/b]
--- Quote End ---
Do you have /dev/console ? I uploaded a rootfs which I used for the test.
http://nioswiki.jot.com/wikihome/operating...s-nios2.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/nfsfilesytem/rootfs-nios2.tar.bz2
In user config,
Core Applications --->
[*] init
[*] enable console shell
Then the init will open /dev/console for a shell.
If you do not select "enable console shell " or you do not have /dev/console, then you have to add a terminal to inittab.
