non-blocking AvMM reads
I have observed that when user application tries to read from a non-existing address the uC hangs, but when doing the same with memory viewer in debug mode, it doesn't. I would assume the debugger is using a different instruction (with some sort of timeout) for read accesses.
Is it possible to use the same in user application?
Thanks!
The JTAG debugger uses the same instructions as 'normal' code.
IIRC the avalon cycle usually completes and returns ~0.
I think there is a menu somewhere to enable a interrupt on an Avalon cycle with an illegal address (but it might be on the 'hidden' options menu).
I've seen problems where such accesses from PCIe 'trash' the PCIe link - but only on one of the many BARs out system has.
Thanks dsl, I'm one step closer :-)
but that option is "so well hidden", I couldn't find anything yet... any idea what keyword I should be looking for?
Indeed, you probably have to ask your FAE how to access the nios 'hidden config menu'.
It contains some useful stuff - some of which probably generates broken cpus.
We found out about it because I needed to disable dynamic branch prediction.
