12748 Discussions
opencores CAN - registry description?
Hi!
I need registry description for Opencores CAN. Does anyone know if there is info on using this core?
Can anyone help?
L.
--- Quote Start ---
originally posted by lukky@Feb 21 2007, 01:59 PM
hi!
i need registry description for opencores can.  does anyone know if there is info on using this core?
can anyone help?
thanks,
l.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21739)
--- quote end ---
--- Quote End ---
See datasheet SJA1000 from Philips (NXP at the moment...).
But if you modify the core a little bit, you can do 32 bit accesses... Which means much less time to send/receive messages (can be importand if this happens at interrupt time).
