IDT SRAM
hello
I am working with stratix II EP2S60.
I cant find any documents about nios programming for sram (IDT SRAM).
for example, how can i write a 32 bit data in known address in nios.
thanks
Dear,
Writing a 32 bit value can be easily done with a NIOS core.
For example:
You make use of a SRAM which has a 32bit databus. You can access this 32b
bus with your NIOS core for example by use of a 32 bit parallel IO bus
(GPIO 32 bit), called SRAM_DATABUS.
Writing to this bus, you can easily do with following pointer instruction. The address is defined in your system.h file.
volatile unsigned int * data = (unsigned int *) (SRAM_DATABUS_BASE);
*data = 0xFFAAFFAA;
The same procedure you can use for writting the SRAM CSn, WRn, RDn, ....
Of course, take into account timigs (setup time, hold time,...) of you SRAM device.
Karel
You may also use the IORD/IOWR_32DIRECT functions
--- Quote Start ---
originally posted by jdhar@Oct 9 2006, 11:37 PM
you may also use the iord/iowr_32direct functions
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18611)
--- quote end ---
--- Quote End ---
I use these 2 functions but i can just write to memory with IOWR_32DIRECT() and i cant read data with IORD_32DIRECT()
--- Quote Start ---
originally posted by m_llaa+oct 10 2006, 03:30 am--><div class='quotetop'>quote (m_llaa @ oct 10 2006, 03:30 am)</div>
--- quote start ---
<!--quotebegin-jdhar@Oct 9 2006, 11:37 PM
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18618)</div>
[/b]
--- Quote End ---
What do you mean you can&#39;t read?
If you&#39;re not seeing the read strobes on the chip, you might be accessing a cached value. Set bit 31 in the read address to bypass the cache.
Hi gomiboy
I am using SRAM with 1024KB, then I have 20 bits for addressing.
this is my simple program in nios. I can write and read.
for(i=1;i<30;i++)
IOWR_32DIRECT(BASE_SRAM,4*i,i+1);
for(beta=1;beta<5;beta++)
alpha = IORD_32DIRECT(BASE_SRAM,4*i);
printf("%x\t",alpha);
but
if in second "for" I increse delay for example for(beta=1;beta<10;beta++)
when I read from SRAM i can just read 0xffffffff
--- Quote Start ---
originally posted by m_llaa@Oct 29 2006, 06:18 AM
hi gomiboy
i am using sram with 1024kb, then i have 20 bits for addressing.
this is my simple program in nios. i can write and read.
          for(i=1;i<30;i++)
            iowr_32direct(base_sram,4*i,i+1);
            alpha = iord_32direct(base_sram,4*i);
but
if in second "for" i increse delay for example for(beta=1;beta<10;beta++)
when i read from sram i can just read 0xffffffff
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18990)
--- quote end ---
--- Quote End ---
was anybody able to resolve these issues? i am using IOWR/RD_32DIRECT, in fact i copied and pasted above code into my program, but was unable to write to or read from the SRAM on the DE2 board. furthermore, when i attempt to read from the SRAM, it is overwritten. any ideas?
