outb()
Can anyone help me with this simple issue?
how to compile such simple test:
# include <sys/io.h>
int main(void)
ioperm(0x340,0x342,1);
outb(0x340,0x0);
exit(0);
there are no outb() function declared in headers....
outb/ioperm, etc. have no meaning in uCLinux, since it&#39;s designed specifically for MMUless processors.
I believe that the IORD/IOWR macros will work, just fine, for you. They can be found @:
# include <io.h>
Cheers,
- slacker
Hello slacker,
I&#39;d like to know if there is a tutorial where I can find the syntax of macros such as IORD or IOWR. If there aren&#39;t any, how can you rewrite aj_&#39;s small program?
thanks.
Hello every body,
I&#39;m sure that someone has already cope with these kind of programs...
It is indeed possible to use outb() and similar in userspace by including <asm/io.h>, or at least it should be.
As far as I remember all the code in asm/io.h is inside# ifdef __KERNEL__, so you have to do some adjustments to this file to be able to access the IO-functions from userspace (refer to f.ex i386).
