performance counter core
hi there,
in my previous message, the code i have was too complicated. I wrote a simple routine to test perfomance counter core. I am running the nios 2/cyclone 2 development kit.
* "Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It runs with or without the MicroC/OS-II RTOS and requires a STDOUT
* device in your system's hardware.
* The memory footprint of this hosted application is ~69 kbytes by default
* using the standard reference design.
* For a reduced footprint version of this template, and an explanation of how
* to reduce the memory footprint for a given application, see the
* "small_hello_world" template.
# include <stdio.h># include "alt_types.h"# include "system.h"# include "altera_avalon_performance_counter.h" /*Use to measure code performance*/
int main()
int count = 0;
PERF_RESET(PERFORMANCE_COUNTER_0_BASE);
PERF_START_MEASURING(PERFORMANCE_COUNTER_0_BASE);
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE, 1);
count++;
printf("Hello from Nios II!\n");
PERF_END(PERFORMANCE_COUNTER_0_BASE, 1);
PERF_STOP_MEASURING(PERFORMANCE_COUNTER_0_BASE);
perf_print_formatted_report((void*)PERFORMANCE_COUNTER_0_BASE, ALT_CPU_FREQ,2, "total", "rate1");
return 0;
I compiled and loaded the program using the nios 2 programmer and I still get the same output
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Hello from Nios II!
--Performance Counter Report--
Total Time: 2.17021E+11 seconds (18446744073709551615 clock-cycles)
| Section | % | Time (sec)| Time (clocks)|Occurrences|
|total | 100|217020518514.23001| -1| 4294967295|
|rate1 | 100|217020518514.23001| -1| 4294967295|
look at how long the total time and -1 in Time. How can this be? anyone has any suggestion?
