12622 Discussions
porblems when generate the zImage
hello guys, i have encounted a problem and came for your kind help.
to generate the zImage file, i input the command 'make', then it has the following errors, what should i do? need to make some patches? i've patched the uClinux-dist.diff.gz provided.
[bigmagic@tu053020 uClinux-dist-test]$ make
make -C tools/ucfront
make[1]: Entering directory `/home/bigmagic/uClinux-dist-test/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/bigmagic/uClinux-dist-test/tools/ucfront'
ln -sf /home/bigmagic/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/bigmagic/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/bigmagic/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/bigmagic/uClinux-dist-test/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/bigmagic/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/bigmagic/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sram_0 cfi_flash_0 < mk.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
CHK include/linux/version.h
CHK include/linux/compile.h
CHK usr/initramfs_list
CC arch/nios2nommu/kernel/time.o
arch/nios2nommu/kernel/time.c: In function `timer_interrupt&#39;:
arch/nios2nommu/kernel/time.c:70: error: `na_timer0&#39; undeclared (first use in this function)
arch/nios2nommu/kernel/time.c:70: error: (Each undeclared identifier is reported only once
arch/nios2nommu/kernel/time.c:70: error: for each function it appears in.)
arch/nios2nommu/kernel/time.c: In function `time_init&#39;:
arch/nios2nommu/kernel/time.c:111: error: `na_timer0_irq&#39; undeclared (first use in this function)
arch/nios2nommu/kernel/time.c:113: error: `na_timer0&#39; undeclared (first use in this function)
arch/nios2nommu/kernel/time.c:118: error: `np_timercontrol_start_mask&#39; undeclared (first use in this function)
arch/nios2nommu/kernel/time.c:119: error: `np_timercontrol_cont_mask&#39; undeclared (first use in this function)
arch/nios2nommu/kernel/time.c:119: error: `np_timercontrol_ito_mask&#39; undeclared (first use in this function)
make[2]: *** [arch/nios2nommu/kernel/time.o] &#38169;&#35823; 1
make[1]: *** [arch/nios2nommu/kernel] &#38169;&#35823; 2
make[1]: Leaving directory `/home/bigmagic/uClinux-dist-test/linux-2.6.x&#39;
make: *** [linux] &#38169;&#35823; 1
anybody met similar problem before? please give some advice on it, thank you very much!!
You need a full-featured timer in your sopc builder.
thank u very much hippo, i added a timer in the sopc builder and the problem is solved.
i compile the kernel under linux, but now that, it shows cannot find nios2-elf-gcc, i should install something else?
thank you again.
--- Quote Start ---
thank you again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16109)
--- quote end ---
--- Quote End ---
What is the message?
check if you have "cc" which is a symlink to "gcc" ?
cc -v
if not,
su -
cd /usr/bin
ln -s gcc cc
Check if you have nios2-linux-uclibc-gcc,
nios2-linux-uclibc-gcc -v
if not, setup the PATH.
hippo,thank you for you kindness, i will try it when i get back to the lab tomorrow.
another question, what&#39;s the size can a smallest uclinux be? is it able to be uploaded to a flash of only 2M BYTE?(with kernel and the file system)?
--- Quote Start ---
another question, what&#39;s the size can a smallest uclinux be? is it able to be uploaded to a flash of only 2m byte?(with kernel and the file system)?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16124)
--- quote end ---
--- Quote End ---
The smallest size of compressed kernel (with initramfs) is around 600KB.
It will grow if you enable more kernel config or more apps,data etc.
The compression rate is around 1:2 .
If you didn&#39;t use complex programs such as ssl/ssh , 2M should be enough.
