12748 Discussions
porting of uclinux onto NIOS II
Hello everyone,
i am a newbie in the porting stuff and i learn that i can port uclinux onto NIOS II processor.
could anyone help me with how to get started with how to port uclinux onto NIOS II processor.
Please suggest me with any good document available which can explain me the steps and commands to port uclinux to NIOS II board.
Ooops ?!?!?
You don't need to port uClinux ontop the NIOS processor, you can just use it.
see http://www.nioswiki.com/operatingsystems/uclinux (http://www.nioswiki.com/operatingsystems/uclinux) .
This page also suggests, that the upcoming version of uClinux for NIOS2 will support the MMU and thus "full" Linux,.
-Michael
thank you for the link...
could you please explain me how do i begin with to use uclinux on NIOS???
can i use NIOS IDE and other stuff in centOS or other linux versions???
thank you in advance
First of all, read the NiosWiki introduction.
You can't use the NIOS IDE, but you need to set up Linux on your PC to develop fort uClinux.
To start testing, if you don't have hardware yet, get yourself a "NEEK" ( see http://www.nioswiki.com/nios2embeddedevaluationkit (http://www.nioswiki.com/nios2embeddedevaluationkit) ) and try out how UCLinux looks like with same ( http://www.nioswiki.com/operatingsystems/u...x/tryoutuclinux (http://www.nioswiki.com/operatingsystems/uclinux/tryoutuclinux) )
-Michael
Thank you Mischael
