power on boot
I am running on the Altera 1c20 devlopment board using the factory configuration.
I understand from previous postings that I need to locate the kernel at 0000 0000 in FLASH in order for it to boot when the reset button is pressed. s this correct?
What do I need to modify in the kernel project to relocate the binary file to 0000 0000?
Thanks for your time,
Shlomo
I'd like to know if there is a shortcut to do this also.
Hi Shlomo,
The kernel should relocate itself to SDRAM ... just program the binary at 0x0.
--Scott
